Thread: motors on which end of screw
	12-10-2011 #1
This is probably a stupid question, but does it matter which end of the lead screws the motors are mounted
. I can see the direction of rotation will alter depending on which end they are mounted, but can this be changed in the software or something
	12-10-2011 #2
Not in the least, whatever fits best.
Direction can be changed in software but it does pay to get the main load / thrust bearing assembly at the motor end, support bearing at trailing end.John S -
	12-10-2011 #3
I dont think it would make any difference to the operation of the screw, but are the ends of the screw not machined differently? One end should be machined to fit a bearing block and the other would be to fit the motor. I would say that the end with the longer machined down section would be for the motor.
Ian
	12-10-2011 #4
	12-10-2011 #5
Hi Dean,
The others have answered your Q but one thing you may not know or be aware of is one end should be fixed (the thrust end John refers too) often this end will have a threaded portion.!
This end will usually be clamped thru 2 angular contact bearings mounted into a bearing mount or plate, reason: so the screw doesn't float back n forth effectively causing backlash. The other end just goes into a normal bearing and is referred to as the floating end.
Knowing the machine you intend to build I think you'll find it's not designed to take 2 angular contact bearings like I describe but a single STD bearing. This will work but there could be some end float, you may want to think about making a slight modification so it use's 2 STD bearings with a slight gap between the outer races then when tightened together it preloads the inner race to the outer removing any float. Or buy the more expensive angular contact bearings which are designed to run this way.!!
Just in case Dean reads up on this it's generally referred to as end float, and often mistaken for backlash.
STD bearing, is that 'STanDard' bearing? If it's the one of the two screws I think it is then it's one of two cases. Either thrust bearing and standard bearing, or a double row angular contact bearing or pair of thrust bearings.
	12-10-2011 #7
Yep STD in my world means Standard.! As in STD Deep grove bearings.
Believe the screws are the ones you sold him so you should know best which they were machined to use.?
Thou to be honest I was just trying to make him aware one end needs to be fixed with a simple example of a cheap way to do it. . . .(Knowing because I cut some bits for him that they didn't look like they were designed for 2 bearings.? )
	13-10-2011 #8
Thought it might be those. Have a look at the first post in my build log to see how I did the shorter screw with a single thrust bearing and 'STD' bearing:
http://www.mycncuk.com/forums/showth...outer-building...
I did the Y similarly but with two thrust bearings. Easier to use double row angular contact. Didn't I include some bearings / mounts with it? I forget...
	13-10-2011 #9
Thanks Jazz,
This makes for some interesting reading, and endfloat is the same as found in crankshafts etc. I do like the simple idea of 2 STD bearings tightened up, but i only nead this on the Z axis as the others will be using bearings etc supplied by Jon.
cheers ,
Dean
	13-10-2011 #10
Another screw problem
By Swarfing in forum Marketplace DiscussionReplies: 5Last Post: 27-03-2013, 09:24 PM -
Ball screw
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 20-10-2011, 01:28 PM -
one lead screw or two
By johngoodrich in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 13-08-2011, 02:39 PM -
FOR SALE: Screw & Nut for Z axis
By phill05 in forum Items For SaleReplies: 0Last Post: 12-06-2010, 05:12 PM -
New build - Screw specification???
By HiltonSteve in forum Linear & Rotary MotionReplies: 25Last Post: 21-05-2009, 08:47 PM
