Thread: motors on which end of screw
12-10-2011 #5
Hi Dean,
The others have answered your Q but one thing you may not know or be aware of is one end should be fixed (the thrust end John refers too) often this end will have a threaded portion.!
This end will usually be clamped thru 2 angular contact bearings mounted into a bearing mount or plate, reason: so the screw doesn't float back n forth effectively causing backlash. The other end just goes into a normal bearing and is referred to as the floating end.
Knowing the machine you intend to build I think you'll find it's not designed to take 2 angular contact bearings like I describe but a single STD bearing. This will work but there could be some end float, you may want to think about making a slight modification so it use's 2 STD bearings with a slight gap between the outer races then when tightened together it preloads the inner race to the outer removing any float. Or buy the more expensive angular contact bearings which are designed to run this way.!!
Another screw problem
By Swarfing in forum Marketplace DiscussionReplies: 5Last Post: 27-03-2013, 09:24 PM -
Ball screw
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 20-10-2011, 01:28 PM -
one lead screw or two
By johngoodrich in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 13-08-2011, 02:39 PM -
FOR SALE: Screw & Nut for Z axis
By phill05 in forum Items For SaleReplies: 0Last Post: 12-06-2010, 05:12 PM -
New build - Screw specification???
By HiltonSteve in forum Linear & Rotary MotionReplies: 25Last Post: 21-05-2009, 08:47 PM
. I can see the direction of rotation will alter depending on which end they are mounted, but can this be changed in the software or something
