	14-10-2011 #1Oh god here we go again.!!! . . . Don't talk soft you can compensate for un-parallel rails in software.!! . . . How.???In mach3 go to "Function Cfg's" then "Formulas". If you can measure the error (dial indicator etc) then it will be possible to work out a forumula to compensate, and eliminate it.i think you changed aurguments there jazz, its unfair of you to talk like your "THE MAN" when your not man enough to admit that you were unaware of mach's ability to compensate..... surly it would be better for you and the rest of us if you had saidSo whats the formula to get Mach to stop loosen the rails eliminate binding and tighten back down.???
"sh*t... how the hell do you do that?" then you me and all the uninitiated you keep going on about might learn some brand new shit
	15-10-2011 #2
No Mark I'm very much Man enough to admit when I don't know something or indeed I'm plain wrong. . which in this case don't feel I am. . . . I'm also very open to learning new shit, Which I do every day.!!
I also know very well about Mach's compensation features, also know they have very limited affect and difficult to impliment. Even Art fennerty Mach's designer agree's they are unrealiable and only to be used in case's or when all else fails and expect limited success.!!
Know I don't really give a flying F@#K what YOU, Jonathan or anybody else thinks about my comments. . . . I do care that people should be mindfull that newbie's will be reading and soaking up these missleading post's and it can and does cost people valuable time and money, even leading to discourageing them to try again when it doesn't perform as expected.
My comments are not in anyway personal to Jonathan, believe me I would be them same regardless who it was and will always challenge information I feel is wrong or missleading.
Not every one likes posting on forums, I know from experience helping those that have had the good sense or courage to ask for help that this is particularly true in both the young and older generations.
They sit back and prefer to skim post's soaking up information both good and bad like sponges, they latch onto anything that seems to fit the bill for there particular needs or requirements.
Comments inferring software can compensate for less than ideal build quality along with other urban cnc myth's like bigger, faster is better etc are latched onto and implimented into first time builds often with disasterous expensive results.
All I'm asking is that influential posters consider what they post and instead of trivialising the need for care while building and they promote and emphasise the advantage good build practice makes instead.!
Jonathan I'm Sorry if I've up set you and know your comments are ment with the best of intentions but I feel you really do need to be more mindfull new people will be reading your post's. A bit more explination and clarification of the short comings of some the suggestions would be more helpfull.
Now with that said I don't want this to escalate any further as it's distracting and not fair to the original posters thread.! . . . For this I do appologise to Justin because I was the one who jumped on Jonathan and started it all but please let's leave it here.!! . . . . . If you feel you must rebuff me then please feel free to PM me.!
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
expanding foam and steel frame
By Gytis in forum Metalwork DiscussionReplies: 11Last Post: 18-08-2013, 10:35 AM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM -
What frame bed and where to buy?
By icedfusion in forum Machine DiscussionReplies: 11Last Post: 13-01-2012, 06:39 PM
