14-10-2011 #2
No I dont think the material is oversized.
If you want a really sturdy machine then you cant really oversize the frame material, within reason I might add. Box section steel itself isnt really that strong unless you start going into heavy wall thickness stuff and as Jazzcnc has said getting your construction right to start with will make all the difference and would save you £800 on machining.
Ian
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
expanding foam and steel frame
By Gytis in forum Metalwork DiscussionReplies: 11Last Post: 18-08-2013, 10:35 AM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM -
What frame bed and where to buy?
By icedfusion in forum Machine DiscussionReplies: 11Last Post: 13-01-2012, 06:39 PM
