14-10-2011 #17Oh god here we go again.!!! . . . Don't talk soft you can compensate for un-parallel rails in software.!! . . . How.???In mach3 go to "Function Cfg's" then "Formulas". If you can measure the error (dial indicator etc) then it will be possible to work out a forumula to compensate, and eliminate it.i think you changed aurguments there jazz, its unfair of you to talk like your "THE MAN" when your not man enough to admit that you were unaware of mach's ability to compensate..... surly it would be better for you and the rest of us if you had saidSo whats the formula to get Mach to stop loosen the rails eliminate binding and tighten back down.???
"sh*t... how the hell do you do that?" then you me and all the uninitiated you keep going on about might learn some brand new shit
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
expanding foam and steel frame
By Gytis in forum Metalwork DiscussionReplies: 11Last Post: 18-08-2013, 10:35 AM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM -
What frame bed and where to buy?
By icedfusion in forum Machine DiscussionReplies: 11Last Post: 13-01-2012, 06:39 PM
