Thread: cutter for MDF
16-10-2011 #1
I have bought a selection of router straight bits from toolstation, around a £1 a bit including delivery. I got these because i know i'm going to break some etc
http://www.toolstation.com/shop/Rout...mperial/p46293.
Would these be ok for cutting shapes, holes, raised lettering etc
16-10-2011 #2
16-10-2011 #3
Deannos, the cutters you linked are ok but tent to squeal a bit, regardless of feeds and speeds, i have found this to be down to the rake of the carbide cutter in this case none, i would suggest you have a play with a few of those the move on and get the similar one made by trend, this has a slight positive rake and cuts a lot nicer.
16-10-2011 #4
Yes, I should have mentioned that. Particularly for me the 6mm cutter squeals and breaks easily.
Another option is the 6mm single flute carbide cutters I keep going on about... they can potentially cause a problem as they are 'upcut' (spirals upwards) so could lift the surface of the MDF but try it and see. It's worked fine for me, plywood was ok with them too.
16-10-2011 #5
I put the premature breaking down to the cutter resonating at its critical frequency, keeping the cutter short as possible will help things a bit!
16-10-2011 #6
Ok, thanks guys, for a pound i will have a play around. As this is all new to me and i have a lot of learning to do
fly cutter advice please
By luke11cnc in forum Tool & Tooling TechnologyReplies: 13Last Post: 07-12-2014, 01:38 PM -
CNC hot wire cutter
By Nstocks in forum Machine DiscussionReplies: 0Last Post: 22-05-2014, 07:54 PM -
Skimming yer bed.... does anyone use a fly cutter?
By HankMcSpank in forum Machine DiscussionReplies: 5Last Post: 08-09-2013, 04:57 PM -
Cutter question
By SimonH in forum Machine DiscussionReplies: 2Last Post: 12-02-2013, 05:50 PM -
Which Plasma Cutter to buy?
By AndyG in forum General DiscussionReplies: 7Last Post: 02-12-2011, 09:34 AM
