    Lives in East Lothian, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 375 times, giving thanks to others 9 times.
    Box section steel is half the price of Ali box section, I pay around £20 for 7.5mtr 50x50x3
    You'd be surprised. I know when I priced a project earlier this year, there wasn't that much difference in price for the box section that I needed. It was all the brackets that bumped the price up. I still went for the alloy though, as it was lighter with less flex which suited the application, and the company cut it all to length so all I had to do was bolt it together, which saved me a lot of time.
    You'd be surprised.
    No I wouldn't 50x50x3 Ali is £35 plus vat + Del (Ali warehouse) for 5mtr and as of 2 weeks ago when I last bought some 50x50x3 steel box section was £21 for 7.5mtr. Inc Vat.! (Delivered thou it's only next village so don't count really. .Lol)
    That's ok if you have the equipment to deal with full lengths
    Equipment = hacksaw (takes a while but it works), or get the supplier to cut it. The place I got mine from cut it without charging, and also gave me a load of free bits :). I worked it out so that each piece would fit in the car, then did the rest of the cutting myself to make sure it was accurate. If I recall correctly the 60x60x3 steel box section I got was £25 for 7.5m.
    Sell the spare on eBay, it goes for lots there!
    If you don't have a pillar drill, scribe, centre punch etc. then
    Then get one ... you're not going to get very far in life without a pillar drill. Well... I wouldn't! Surely you would need both for aluminium or steel.
    Also to get the same strength in Ali you'd need more than 3mm thick...so comparing like with like would make the difference in price even greater. Also I think Tom was comparing aluminium profile to steel box, and profile is a lot more expensive than box (though also significantly stronger for the same outside dimensions).
    Two weeks ago... does this mean you've started the next machine?
    Nope that beast will be 100x100 filled with sand and built like a brick shit house.!! . . . Was for steel door at work to stop thiefing bastards.!!
    One other great tool and cheap thats quick for cutting steel is 1mm micro cutting disc's in angle grinder, go thru like hot knife in butter, they also easily go thru hardened rails and Pad locks.!
    quick for cutting steel is 1mm micro cutting disc...easily go thru hardened rails and Pad locks.!
    Surely the logical conclusion from those two statements is that the thieves just need a 1mm cutting disk. :clap:
    Yep but what more can you do.? . . . The Health n safety gestapo won't let me wire it to the mains like I want to. . . . . .They don't like shot gun wired to PIR either miserable bastards.
    Actually been told by a steel fab shop that if you put plywood behind the steel it dulls the thin blades and they have hard time cutting thru.? . . . Don't know but I've done it for sake of £20.!
  1. Time for a new machine - need help!
    By Isaac in forum Machine Discussion
    Last Post: 19-05-2014, 02:04 AM
  2. Profile Cutting Options BobCAD CAM
    By aldepoalo in forum BobCAD-CAM
    Last Post: 25-06-2013, 09:10 PM
  3. water cooling options for spindle
    By routercnc in forum Tool & Tooling Technology
    Last Post: 12-02-2012, 11:22 PM
  4. time to gather parts for new machine
    By deannos in forum Gantry/Router Machines & Building
    Last Post: 21-01-2012, 02:23 PM
  5. limit switch connector options?
    By routercnc in forum General Electronics
    Last Post: 04-09-2010, 02:11 PM
