Sorry, but having reread my post it was not very clear. I was thinking of
a) casting the rails using epoxy granite
b) using the plastic i beams for rails
Both a and b would then have a 50mm * 40mm machined aluminium section attached which has been precision milled to hold the linear guide rails.
The other option and I would love to explore it, would be to make the rails using composite materials. eg foam which has been layered with carbon. Carbon is super stiff and I suspect you would end up with a very stiff and light rail ?
The plastic beams you are referring to in that link is the same thing as plastic decking. Have a look here
http://www.ebay.co.uk/itm/Recycled-s...item5adfe7aa65
This stuff still flexes but good over short lengths. Might give some a try myself.If the nagging gets really bad......Get a bigger shed:naughty:
Laminate plastic help!
By totts in forum Marketplace DiscussionReplies: 7Last Post: 13-04-2013, 07:14 PM -
Some kind of plastic needed
By m_c in forum General DiscussionReplies: 26Last Post: 08-04-2013, 12:29 PM -
x-axis rails and lead screw
By adambrum in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 13-08-2011, 01:56 PM -
2 ply plastic help
By h4ppy-chris in forum General DiscussionReplies: 8Last Post: 30-01-2011, 04:54 PM -
Looking for thin plastic? sheet
By irving2008 in forum Machine DiscussionReplies: 19Last Post: 09-09-2010, 12:32 AM
