    oh, they did!
    http://wimp.com/squareholes/
    it took a warped mind to come up with that one!
    You can actually use a similar technique to 'drill' a variety of other shapes, such as hexagons.... even timing pulleys. Try searching 'rotary broach' on YouTube.
    Lives in East Lothian, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    The triangular drill for drilling square holes has been around for a long time. It relies on a floating chuck to allow the drill to wander around the hole while still being rotated.
    Geometery is shown well on this page - http://www.maa.org/mathtourist/matht..._08_31_09.html
    You can do more than square holes, but it's not really that commonly used, as rotary broaching is a more versatile technique.
    Slight difference in the way they work.
    rotary broaching can only work to about 2X the diameter of the tool in depth.
    the cutting in the video can go far longer and stay vertical.
    It's based on the Watts drill that was patented in 1918 but known about long before that.
    http://www.youtube.com/watch?NR=1&v=JeIi04JoAoo
    John S -
  1. What tooling to drill lots of 10mm holes 45mm deep?
    By AlanMJackson in forum Tool & Tooling Technology
    Last Post: 13-01-2014, 08:53 PM
  2. Ok PCB milled now how to drill the holes ?
    By Fivetide in forum CAD & CAM Software
    Last Post: 12-05-2013, 08:31 PM
  3. Drill 4 x 28mm holes through 44mm thick aluminium
    By WandrinAndy in forum Gantry/Router Machines & Building
    Last Post: 30-09-2012, 09:17 AM
  4. RFQ: RFQ: 3 x M5 holes drilled and tapped/ +/- 0.01mm required
    By neurofen in forum Projects, Jobs & Requests
    Last Post: 25-01-2012, 04:26 PM
