Ok im going to summarize the parts so far.
Im building a wooden constructed belt driven plotter using these parts from:
http://www.ebay.co.uk/itm/CNC-Kit-3-...item2a14d75139
i need to choose the correct belt size as in width i take it i can use smaller belt for
the shorter Y and wider for the longer x ...say 10mm / 25mm?
15 tooth pulleys ok?
Are these steppers man enough?
3M pitch belt driven with 15 tooth pulley gives you 45 mm of axis movement per revolution of driving pulley. Reducing it further 5x gives you 9mm/rev. Driving it with stepper (after reduction) @1/2 step (400 steps/rev) gives you 0.0225mm resolution. I think its enough for your boat drawing or even for cutting
Driving it directly with 15 tooth pulley @1/2 step will give you 0.1125mm resolution
07-11-2011 #2
These links don't show up for me.?
Regards pulley size I really wouldn't use 15T see post #21 for reason why.! . . . Belts are great but there are some things that must be done correctly or premature belt wear leading to failure is very easy. . .These things are: 1: Correct belt width appropriate to load 2: Correct pully size regards Tooth engagemant 3: Alignment 4:Tension
Belt driven CNC mill - some questions
By Cyclonit in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 30-04-2014, 12:39 AM -
Driver & Driven
By manofgresley in forum Stepper & Servo MotorsReplies: 7Last Post: 16-09-2013, 03:43 PM -
stepper motors not being driven
By sprint in forum Machine Control SoftwareReplies: 4Last Post: 12-02-2013, 03:42 AM -
2 Motors driven from one driver in parallel
By fozziebear40 in forum Motor Drivers & ControllersReplies: 5Last Post: 12-07-2012, 09:22 AM -
BUILD LOG: Belt driven 3 axis machine
By Swarfing in forum DIY Router Build LogsReplies: 14Last Post: 21-02-2010, 10:46 PM
