Thread: Driver Lights Red
Page 23/24 of this may help you to identify the fault:
http://www.slidesandballscrews.com/p...l%20090806.pdf
The enables are active low, so as long as they are not connected it should work.
05-11-2011 #2
Cheers for quik response,
Motors-SY60STH86
Wiring setup,black/white n green/white together B-
black n green together B+
red/white n blue/white together A-
red n white together A+
Breakerboard setup is
x axis pin 2 pul+,pin3 dir+
y axis pin 4 pul+,pin5 dir+
z axis pin 6 pul+,pin7 dir+
Regarding mach3 pin port settings i havent really got a clue yet what settings to enter
05-11-2011 #3
That's wrong... you've got one coil on each phase backwards.
- B- Green--Black/white
- B+ Black--Green/white
- A- Yellow--Red/white
- A+ Red--Yellow/white
Lucky your drivers are protected against wiring wrong!
I'll post about the breakout board later if you need it... hopefully it'll all work once the wiring is sorted.
Basically you look on the breakout board manual for which axis each pin is set to and enter those in the ports and pins setup in mach3. Then set the E-stop pin on the inputs tab otherwise nothing will work...
05-11-2011 #4
cheers jonathan that works great, but now a quik ?
first time playing around with movement 5 mins ok, powered down switched of,went for cuppa
went to switch on 5 mins later and the single psu running single driver went bang(nothing altered or touched).opened the psu and behold a small black chip on circuit board near to rear blew up---was it me or just bad luck,can i get new chip or what.(£80quid a new one)
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Help with Supply Indicator Lights
By GTJim in forum General ElectronicsReplies: 7Last Post: 03-09-2013, 08:49 PM -
Which stepper driver
By Colin Barron in forum Motor Drivers & ControllersReplies: 0Last Post: 25-09-2010, 08:33 PM -
Driver wiring help...
By mike in forum Motor Drivers & ControllersReplies: 12Last Post: 21-09-2010, 09:29 AM -
Driver box
By John S in forum General ElectronicsReplies: 1Last Post: 21-06-2009, 12:46 PM
