Either has not safe Z set or the code is setting Z to cutting depth before moving. Common problem with some g-code programs. With BobCAD you have to taylor the post processor or it will skim over at Z0 to the first cutting location which is not good practice. Check your code as that will tell you the moves and will also tell you that units it thinks it is working in. From there it should be pretty straight forward on finding where the error is. Fixing it will be finding where that control for z is in the ArtCAM set up.
Michael
07-11-2011 #2
feedtrate on NCstudio for Artcam problem
By Fivetide in forum Machine Control SoftwareReplies: 2Last Post: 23-12-2021, 09:11 PM -
Help Please With Auto Tool Height Mach 3 Problem
By howser37 in forum Probing, Digitizing & ScaningReplies: 26Last Post: 12-06-2014, 07:55 PM -
Tool Height Setting Probe - Mach3 - solution
By HiltonSteve in forum Tool & Tooling TechnologyReplies: 18Last Post: 12-11-2013, 06:23 PM -
ArtCAM Express 2011 - £99!
By Leighton in forum ArtcamReplies: 4Last Post: 09-05-2011, 01:47 PM -
Setting Z height with an ER32 collet
By Robin Hewitt in forum Machine DiscussionReplies: 0Last Post: 27-03-2010, 09:16 PM
