    Basically I've got a bog standard router like below:
    http://www.screwfix.com/p/direct-pow...ter-230v/25568
    What I want to do is insert a cutter into the router but the shaft is only 3mm and the collet on the router is alot bigger.
    Can anyone tell me if I can get a sleeve to adapt it and if so where from. The like of screwfix and B&Q dont seem to do them.
    Matt
    just type collect in to ebay
    try this link
    http://www.ebay.co.uk/sch/i.html?_fr...All-Categories
    James
    I think 3mm is 1/8" but I'm sure some one will correct me if I'm wrong
    so you need 1/8 to 1/4" collet
    James
    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Quote Originally Posted by luke11cnc View Post
    just type collet in to ebay
    1/8" = 3.175mm
    1/4" = 6.35mm
    I don't know anything about router collets though!
  5. That looks to be the same as B&Q's Performance Power range of routers.
    Trend do make collect sleeve's, but I ended up using my friends mini metal lathe an make my own collect's.
    "If first you don't succeed, redefine success"
    Quote Originally Posted by Mad Professor View Post
    I made some for mine using CNC mill operated as a cnc lathe. Could have made them manually on the lathe easily enough...I'll see if I can find them as I have no use for them now.
    Edit: Looks like I videoed it, see here...
    http://www.youtube.com/user/Jonbliss...17/m98fPg-_vUU
    For future reference if you can't remember it's 1" to 25.4mm then use Google:
    http://www.google.co.uk/search?gcx=w...w=1366&bih=667
    (There's various ways you can type it and it will convert pretty much anything, for instance:
    http://www.google.co.uk/search?gcx=w...w=1366&bih=667)
    Considering the runout on those routers saying 3mm is 1/8" is not far off!
  1. 66 Piece TCT Router Cutter Set for £120 on Rutlands website for 48 hours
    By WandrinAndy in forum Marketplace Discussion
    Last Post: 30-08-2012, 11:41 PM
  2. Lubricant for router cutter?
    By Richie in forum Tool & Tooling Technology
    Last Post: 28-04-2012, 12:26 AM
  3. cutter for MDF
    By deannos in forum Tool & Tooling Technology
    Last Post: 16-10-2011, 09:33 PM
  4. First Plasma Cutter
    By antsals in forum Plasma Table Machines
    Last Post: 16-05-2011, 07:58 AM
  5. RFQ: Looking for someone to design and build me a cnc pipe router/cutter
    By D-man in forum Projects, Jobs & Requests
    Last Post: 07-11-2010, 01:59 PM
