Thread: thought i knew but i don't,help
	12-11-2011 #1
Ok i have the following,
MSD 542 drivers
M60STH88-3008DF motors
Routout CNC 25 way D BOB
Now i understand its best to wire this in Bipolar parallel, but thats all i know. I have got diagrams and i still don't get it. Can some one please do me a simple,easy to read diagram, walk through etc. Because at the moment i'm :confused:
am i right in thinking the motors wires would be paired as
A+ Blue-Red
A Blue/w-Red/w
B+ Green-Black
B Green/w-black/w
Ok i think i understand it now, just need my wire combos checking by someone.
Also do i ignore the ENA pins on the driversLast edited by deannos; 12-11-2011 at 08:19 PM.
	12-11-2011 #2
The Following User Says Thank You to Jonathan For This Useful Post:
	13-11-2011 #3
	13-11-2011 #4
[QUOTE=Jonathan;25682]No...that's a short circuit
A+ = Red + Blue/White
A- = Red/White + Blue
B+ = Green + Black/White
B- = Green/White + Black
Bipolar series gets better torque at very low speed, so it's not much use for you.
I think i understand it now, so should the B+ and B- colours be switched?Last edited by deannos; 13-11-2011 at 03:07 AM.
	13-11-2011 #5
If you reverse A+ A- or B+ B- you reverse the motor.
	13-11-2011 #6
That's in parallel, by all means try series and let us know the difference.
Yours are on the 240V drivers though, and at that voltage (340v ish when rectified) the current can change very fast even in series, so they're better off in series to reduce the heat.
Put your motors in parallel then see if you can get 25mm/s :naughty:
(No DON'T do that, just kidding)
Further reading:
http://www.mycncuk.com/forums/showth...ll=1#post25191Last edited by Jonathan; 13-11-2011 at 09:13 AM.
	13-11-2011 #7
If i follow the colours on this data sheet, the A+ A- match up, but the B+ B- seem reversed to the colours Jon posted. Am i reading it wrong, i'm looking at the diagram bottom right
www.motioncontrolproducts.com/pdfs/M60STH88-3008DF.pdfLast edited by deannos; 13-11-2011 at 11:01 AM.
	13-11-2011 #8
What I posted is fine - as Robin said if you swap A+ and A-, OR B+ and B- the motor will just spin the other way... i.e. if you change the current direction in either phase.
Just a thought, a google map of member locations
By D-man in forum General DiscussionReplies: 37Last Post: 09-04-2013, 02:38 AM -
Not getting speeds I thought I would?
By jonbabbz in forum General DiscussionReplies: 5Last Post: 29-09-2012, 09:56 PM -
I saw this & thought of you (cheap touch screen/display for CNC useage)
By HankMcSpank in forum General DiscussionReplies: 1Last Post: 29-05-2011, 08:15 PM -
Thought you might like to see what i have been playing with ?
By John S in forum Computer SoftwareReplies: 4Last Post: 07-10-2010, 09:15 AM -
NEW MEMBER: Thought id join
By cooliced in forum New Member IntroductionsReplies: 4Last Post: 17-08-2010, 02:30 AM
