16-11-2011 #1
So I've bought a few used endmills off ebay (I have a habit of snapping them, which hurts when you pay new) ...bit of a lucky dip of 15 end mills/drills.
So how do I establish the true diameter of these - I have digital calipers, but even those end mills I already own & I know the cutting diameter, they measure under - eg 2.00m diameter end mills on my digitial calipers read about 1.86mm (or thereabouts), is it just a case of rounding up?
16-11-2011 #2i wouldnt do that ? you want to be telling your cam software exact sizesis it just a case of rounding up?
with vernier calipers i use the full length of the faces of the calipers to pinch as much of the cutting section of the tool as i can
i guess makes more sense to use a micrometer but that can be a pain as there are peaks and troughs when measuring with such a small surface aria that micrometers have so in that situation i revolve the tool in the mic until it starts to grip (revolve the tool away from the cutting direction)
youll get a feel for it
16-11-2011 #3
I think a micrometer is the best bet as callipers can easily be fooled by positioning it wrong etc. If the cutter has an odd number of flutes then neither will get far...
As they were from eBay the cutters may have been reground, which would make them slightly under the original standard (metric or imperial) dimension. I would start with using the nearest round number (unless it's way off) on something that's not critical, measure the part and compensate from that. It all depends on just how accurate you want to be.
16-11-2011 #4im pretty sure as long as your flutes have at least one rotation (or just over) the verniers should be as close as verniers are accurate even on a single fluteIf the cutter has an odd number of flutes then neither will get far...
16-11-2011 #5
16-11-2011 #6
Nobody has mentioned how many flutes, if it's a three flute you been a vee mice or better still take a cut on some scrap and measure what it actually cuts.
John S -
17-11-2011 #7
You can buy a micrometer just for this job. I'm sure if you hunt around eBay you should be able to pick some up. The have two faces opposite the anvil. I'll see if I can get a picture of a set.
Ant
17-11-2011 #8i guess we all do a bit of that in a sense when we are polishing a g-code filecut on some scrap and measure what it actually cuts.
you have the added complication of climb vs conventional and slot cutting flexing tools this way and that.
i do quite a bit with 3.175mm (1/8) tooling (lots of flex) hence the g-code polishing..... on my first run of a complex part i assume it will have small errors that may make assembly a bit of a pain... tune the code run again etc.... usualy my third part is a winner and that g-code file goes into a file reserved for good code
17-11-2011 #9
Thanks guys....I'll go with the cut/measure option!
18-11-2011 #10
Just found one...... http://www.mitutoyo.co.uk/MitProd/mt...1!Opendocument but taking a cut in material is also an option I have in the past input the size around nominal knowing the cutter is bigger so dependant what you are doing eg inside slot or outside it would leave metal on the component all over. Then check how bit it all is and adjust the offset accordingly. It means you get a good component first time.
Ant
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
advise on drive shaft diameters
By bmbaz in forum Machine DiscussionReplies: 2Last Post: 15-05-2014, 10:46 AM -
FOR SALE: How to measure the use of the imperial bearing temperature
By uitshguai in forum Items For SaleReplies: 3Last Post: 27-04-2014, 01:36 PM -
Accurate Tape Measure?
By Tenson in forum Tool & Tooling TechnologyReplies: 19Last Post: 26-05-2012, 04:41 PM -
how to measure a ring for cnc.
By crimsonred in forum Probing, Digitizing & ScaningReplies: 4Last Post: 27-09-2010, 02:47 PM
