Just found one...... http://www.mitutoyo.co.uk/MitProd/mt...1!Opendocument but taking a cut in material is also an option I have in the past input the size around nominal knowing the cutter is bigger so dependant what you are doing eg inside slot or outside it would leave metal on the component all over. Then check how bit it all is and adjust the offset accordingly. It means you get a good component first time.
Ant
21-11-2011 #2
2.00mm EM reading 1.86mm?
Not sure what cutters you're measuring (3 or 4 flute), or what you're measuring with (calipers or mic), but one point I'll mention is that it is easy to overdo pressure on your measuring tool (ie pushing a caliper too far or tightening a mic too far) and giving a false reading. I have seen people (even in the trade) tighten mic's like g-clamps (not good, because it twists the frame).
If its a 4-flute, slide it until caliper jaws *just* touch, and rotate it until you get the highest reading - this is your actual size.
You say the cutters are from ebay - in which case they may be worn anyway (not knowing how they've been used / treated).
One other point of note: re-ground cutters can sometimes cut slightly oversize.
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
advise on drive shaft diameters
By bmbaz in forum Machine DiscussionReplies: 2Last Post: 15-05-2014, 10:46 AM -
FOR SALE: How to measure the use of the imperial bearing temperature
By uitshguai in forum Items For SaleReplies: 3Last Post: 27-04-2014, 01:36 PM -
Accurate Tape Measure?
By Tenson in forum Tool & Tooling TechnologyReplies: 19Last Post: 26-05-2012, 04:41 PM -
how to measure a ring for cnc.
By crimsonred in forum Probing, Digitizing & ScaningReplies: 4Last Post: 27-09-2010, 02:47 PM
