Thread: Not quite a build log, yet...
17-11-2011 #3
Here it is:
http://www.mycncuk.com/forums/showth...ess-calculator
It's a useful spreadsheet, but it wont give useful results here as you're adding the side plates mainly to counter forces parallel to the Y-axis, not X. Since the force is parallel to the plate the plate does not need to be very thick at all - 5mm would be fine, so long as it doesn't bend - so stiffen the plate if necessary.Last edited by Jonathan; 17-11-2011 at 01:37 AM.
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
