Thread: wiring e-stop button
20-11-2011 #5
Wire the switch so the circuit is made (NC) then when you hit the switch it breaks the circuit. Really it doesn't matter which way because you can change the active hi -lo setting but best wired NC then if the wire breaks the machine will stop letting you know something is wrong.
If your just testing the system then wiring the E-stop this way which is basicly software controlled is ok. But if you want to be truely protect your machine and your self then you ought to look at using a hard wired E-stop that kills the power rather than just tells the software to stop. Software driven E-stop is NOT safe.
See my Edit of #4Last edited by JAZZCNC; 20-11-2011 at 10:58 PM.
Help with Mach 3 REF all Home Button
By Kevin1970 in forum Artsoft Mach (3 & 4)Replies: 11Last Post: 23-04-2015, 10:54 AM -
Mach3 Using a physical button to repeat current gcode
By RLKS Rob in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 12-08-2012, 01:30 PM -
Donate Button
By Ricardoco in forum General DiscussionReplies: 8Last Post: 08-09-2011, 10:32 PM -
Machine co-ordinates button in Mach 3
By alan2525 in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 14-04-2010, 10:57 PM -
Wiring in power and E-stop on DIYCNC Board
By m.marino in forum General ElectronicsReplies: 2Last Post: 10-05-2009, 10:15 AM
