Page 2 of 2 FirstFirst 12
    Quote Originally Posted by wiatroda View Post
    It's not cranking itself , but pulling back handle to unlock is painful as the spring is really strong- too strong.
    I didn't use a dividing plate, never really seen the point when the rotary table has a scale which just move to the right angle.
    What about making some macro with some loop working until machine cut desired amount of tooth???? some no. of tooth variable in a macro??
    If you use EMC you can do it in just a few lines of code as, unlike mach3, it supports loops. I just wrote a quick program to write the code for pulleys:
    http://www.mycncuk.com/forums/showth...ating-programs
    The main reason I did that program was for milling XL pulleys using just a normal endmill, but you can use it with a form tool too.
    Double post, deleted.
    Ooooo! Nice! A nice spinner, Two more blades, a collective pitch head, free electricity? How about a Turners cube? In one go with an under cut tool like a dovetale. Or something on the same lines? Should keep you busy for a bit ;-)
    Tom
    Sherline lathe, Chester DB11V lathe, Myford/ Rodney mill, CNC mill Isel/ home made, Sealy Hack Saw, Meddings Pillar drill.
  5. #15
    @Jonathan, can you please take a picture of the spindle holder plate and tell me how you mounted it to the rotary table. thank you
  6. #16
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 5 Days Ago Has a total post count of 1,654. Received thanks 115 times, giving thanks to others 71 times.
    Quote Originally Posted by totti View Post
    You realise you have responded to a thread that more than 10 years old?
  1. Replies: 12
    Last Post: 25-05-2013, 12:41 AM
  2. RFQ: Z axis and y axis carriage
    By D-man in forum Projects, Jobs & Requests
    Last Post: 08-04-2013, 10:06 AM
  3. NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
  4. Y axis is making X axis stall...!!
    By fasteddy in forum Machine Discussion
    Last Post: 24-10-2011, 12:19 PM
  5. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
