The third casting was indeed for a saddle I'm trying to get the saddle casting to also mount the spindle casting for a mill with vertical hiwin rails
So it can accept the slides for a lathe but it could also do double duty in that I could take the spindle casting dowel and bolt it on and use the same casting for the mill
I havent ruled out epoxy granite for the bed but feel it isnt needed on a hobby size machine its not worth it,Ive done epoxy granite before for a company called zeiss over in germany ,they were damn accurate machines but hey as hobbyist or gor precision engineering it seems we might get a bit hung up on how accurate the machine is
The head casting could take a bored through hole Insert a ground master and moglice it to take a cartridge spindle.
The actual casting cost for the head is 37 quid each and the saddle 17 quid im expecting the bed to be a bit more based on him getting back to me, however the grinder i qot a quote from in sheffield will segmentally grind then line grind the A datum top and B datum foot of the bed casting flat to within 0.05 for 25 quid which seems damn reasonable.
My weak area is electronics I have seen these electronic leadscrews that let you program a pendant to machine instead of using full cnc control I would liketo have some manual control of the lathe without it being connected to a pc using MPG'S TO DRIVE THE STEPPERS does anyone know anything about this?
Ill also cross link this post/ question over on another more electronically oriented part of the forum.
27-04-2012 #2
27-04-2012 #3
Non ferrous is my bag. The furnace is 600,000BTU so its capable of doing iron. The issue is lifting that weight as I work with a crucible. I'm sure within the DIY casting, a cupula would be better as you can tap straight into the mould (if your good). I can get one offs done in a few steel/iron foundry's in Sheffield.
The popular misconception is that iron is easy. In reality its the hardest. Personally I'd use alloy or brass every time. Much easier and cheaper to do.
Casting weight is what ever I can lift. 30KG at 800C takes a bit of bottle though.
29-04-2012 #4
Hi all been busy with other stuff ,drawing up castings on pro engineer and playing with cast epoxy carbon fibre and some sand and rocks ,which is technology I have used before ,I do need to get down to see elfin (i still got your number fella) plus worklife has been taking precedence
oh almost forgot i came across these
http://www.klippfeld.at/frame_en/bil...rodukte=zusatz
and they dont cost too much to buyLast edited by compositepro; 29-04-2012 at 05:57 PM.
NEW MEMBER: Hello all, New member here from London, keen woodworker and interest in homebuild
By justice86 in forum New Member IntroductionsReplies: 0Last Post: 06-11-2013, 01:02 AM
