Thread: wiring the drivers to the BOB
Cool so use the cores like you are then, at the driver end strip the outer sheath and the screen back to something your comfortable with, then at the BOB end of the cable connect up like you have for the drivers but this time when you strip the outer sheath for the main cable keep the screen intact as best you can and then connect the screen to a common earth point.
Basically if I understand right, you only connect the screen at one end so it can discharge, if it was connected at both ends then the discharge wouldn’t happen and the charge would just move around the circuit in a loop.
.Me
The Following User Says Thank You to Lee Roberts For This Useful Post:
Help Make 1st Step - Wiring Up Drivers to Motor and Arduino
By Treemonkey in forum General ElectronicsReplies: 10Last Post: 25-04-2013, 05:47 PM -
Help wiring M60STH88-3008DF Steppers Motors to 752 Drivers
By Mad Professor in forum Stepper & Servo MotorsReplies: 12Last Post: 01-09-2011, 10:09 AM -
Has anyone used these steppers or drivers?
By Jonathan in forum Stepper & Servo MotorsReplies: 2Last Post: 24-03-2011, 02:24 PM -
Gecko drivers
By kingfisher in forum Motor Drivers & ControllersReplies: 0Last Post: 10-10-2009, 08:34 PM -
Steppers and drivers
By Davidh in forum Motor Drivers & ControllersReplies: 3Last Post: 12-06-2009, 05:59 PM
