Thread: Just joined, hobby level
Hi
A bit bored tonight. Looked at your site, Good stuff mate! Had a few whiskys so may be errors! If you need to do other regular shapes just replace the circle equation with your own but it assumes a hemisphere and cheats by using the centre to tool contact as the normal, for elipses etc may be different but for regular shapes you can use the focus. Anything planar is easy. If you let me know the equation of the surface I will tell you the eq of the normal. These are just the finish cuts of course, you will have to cut the other material out with concentric circles keeping z constant. Other surfaces are the same, just need to know the normal vector. Actually you could incorporate a tool deflection number as well relatively easily. This is all to the centre of radius of the tool, just adjust the z path by the radius if you need to work to the tooltip.
Something to play with ...
http://homepage.ntlworld.com/tombayes/public/Book1.xls
Change the numbers in red.Last edited by black5f; 03-12-2011 at 01:03 AM.
Sherline lathe, Chester DB11V lathe, Myford/ Rodney mill, CNC mill Isel/ home made, Sealy Hack Saw, Meddings Pillar drill.
help needed going to the next level
By luke11cnc in forum Computer SoftwareReplies: 8Last Post: 20-09-2012, 08:53 AM -
NEW MEMBER: Just joined up
By PRB in forum New Member IntroductionsReplies: 1Last Post: 18-03-2012, 09:46 PM -
RFQ: Parts for my hobby from your hobby
By Phobia1 in forum Projects, Jobs & RequestsReplies: 1Last Post: 18-01-2011, 02:57 PM -
Level Y Axis
By sfallan in forum Machine DiscussionReplies: 3Last Post: 26-09-2010, 12:52 PM -
NEW MEMBER: Hello i have just joined up
By ieezitin in forum New Member IntroductionsReplies: 3Last Post: 06-03-2010, 11:30 PM
