    Lives in East Lothian, United Kingdom. Last Activity: 3 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    I know it's not the most ideal way to test, but ammeter in the earth wires to see if there's any measureable leakage?
    Should at least be able to isolate if it's the VFD, or motor causing problems.
    I did that, second to last bullet point. But thanks anyway...
    If the problem persists I could try putting a shunt resistor in the earth wire and leaving the oscilloscope (DSO) monitoring it. Set the trigger to whatever voltage corresponds to say 10mA, or just under 30mA (something like that) and see what I get when it trips.
  1. VFD Tripping an RCD
    By Washout in forum Spindles & Drive Motors
    Last Post: 04-09-2017, 02:07 PM
  2. RCD tripping
    By motoxy in forum General Electronics
    Last Post: 23-02-2013, 09:36 PM
