	26-11-2011 #1Im considering the following for converting an SPG 2217 111LV to CNC. Ballscrews are on order (5mm pitch), but what about drivers and steppers?
 Thinking of either a gecko G540 or CNC4you 4.5A driver http://www.cnc4you.co.uk/index.php?r...&product_id=31 with their 4Nm steppers http://www.cnc4you.co.uk/index.php?r...&product_id=70 and the CNC4you breakout board.
 Id love some feedback from anyone who has used them.
 Mark
	27-11-2011 #2Im pretty sure things will be ok, as its owned by Lee who runs this forum!
 *** edit, would help if i read the post properly ignore what i just said lol
	27-11-2011 #3What size machine are you building? 10mm pitch screws might have been a better choice if it's not too late. Only guessing though, not enough information.
 Not sure about the drivers. Bit expensive for a 50V driver (compare it to eBay m542) unless there really is something special about it ... like vector current control. You'd have thought they'd advertise if it was something specific. 1Mhz pulse input is essentially useless for us. The gecko is very likely to be better, but it depends what you're using it for. Might be better but if you don't need that then there's no point, so save the money.
 The motors looks promising, don't think anyone on this forum has used the 4Nm motors. I almost bought a couple for my machine's X-axis to replace the 3Nm steppers, but decided it wasn't really worth it as it'd only make it go faster which doesn't really achieve much. The specifications for those motors look good ... try it and let us know! Run them on M752 / M880N or similar 70-80 volt drivers for best performance (>torque at >speed).
    The Following User Says Thank You to Jonathan For This Useful Post:
	27-11-2011 #4Here is a link to a build thread of a similar machine to the one ive ordered. http://www.cnczone.com/forums/bencht...cnc_plans.html. I Just want to avoid shipping from the US from Kelling as the servos and power supply's cost so much because of the weight. Also would be good to support UK business (even if most of the stock seams to come from China!)
	27-11-2011 #5Ive just seen the DIYCNC website and their 5a system. This seems quite nice and maybe uk built?? There is then of course Gecko G540 but im not sure if this is powerful enough. SO many ways to go!!!!
 Mark
	29-11-2011 #6If your machine is like the X3, as the pictures in the link show, then the standard 1605 ballnut wont fit between the X and Y axis without modiftication.
 To solve this problem, then you will need to use a lower profile ballnut like the FSI of FDI type.Visit Us: www.automationshop.co.uk
	29-11-2011 #7Gary,
 I beg to differ but I have recently fitted a long bed to an X3 using one of those standard 1605 ballscrews on the X axis but you do have to mount it differently.
 Not fitted one to the Y axis as it already had an existing ballscrew fitted.John S -
	29-11-2011 #8Hi
 The machine is like a Grizzley G0704, not an X3 and you have to cut part of the ballnut away. It seems well documented on CNCzone (see link at top with drgs etc).
 However im struggling more with the steppers and Drivers. Most people over there are using Kelling drivers and 381/425oz direct drive steppers on x and y and 906oz direct stepper on Z, (and some only using a Gecko G540). I would like to know what the options are for kit from the UK that works as a package, its not worth importing from US with tax and shipping (weight of steppers and PSU) etc.
 Gary you should have an equiry from me via your website .
 Mark
	29-11-2011 #9Mark,
 Didnt see any email from you.
 Call me on 01202 237770 or email me on [email protected]
 Check to see if the FSI type nut will fit before butchering the ballnut.
 the dimensions are on our website under the gten brand of ballscrews.Visit Us: www.automationshop.co.uk
	29-11-2011 #10Didnt look at the link, just googled the mill.
 you can use 3nm motors on the X and Y and a midle size nema 34 on the Z, but, if you can fit smaller nema 34 on the X and Y, i would think it would be better.
 you can also gear the X and Y with a 2:1 as well if using a 3nm motor
 This will add to the resolution and give you a but more grunt as well.Visit Us: www.automationshop.co.uk
  Matching Drivers with SteppersBy hoppo in forum Motor Drivers & ControllersReplies: 4Last Post: 21-11-2012, 01:19 PM
  Optimum voltage for M60STH88-3008DF steppers and 752 drivers?By Mad Professor in forum Stepper & Servo MotorsReplies: 6Last Post: 26-08-2012, 09:38 PM
  Has anyone used these steppers or drivers?By Jonathan in forum Stepper & Servo MotorsReplies: 2Last Post: 24-03-2011, 02:24 PM
  Are the Zapp 3NM steppers good with their PM-752 drivers?By Jonathan in forum Stepper & Servo MotorsReplies: 19Last Post: 28-05-2010, 03:34 PM
  Steppers and driversBy Davidh in forum Motor Drivers & ControllersReplies: 3Last Post: 12-06-2009, 05:59 PM
