Thread: ATX cycling fault?
YES ATX has control of the power supply, so it really does not sound like there is an issue with the PSU.
There should be an option to display Power On Self Test results to the screen, and to perform all the BIOS POSTs. It does want to and is trying to tell you what is wrong with it.
"Some older Dell computers use an alternate key sequence instead of <F2> to enter System Setup. These key sequences include:
<Ctrl>+<Alt>+<Enter>
<Delete>
<Fn>+<F1> (laptop computers only)
<Fn>+<Esc> (laptop computers only)"
http://www.techrepublic.com/i/tr/dow...rror_codes.pdf
First you need to know that the CMOS memory (that stores all the BIOS settings) has not been corrupted or blanked due to the battery cell on the MB not being charged in use or just demise from natural causes.
Get into the BIOS and be sure that the HDD(s) are configured.
Clearly an awesome opportunity to get an Apple :-)
Jon
The Following User Says Thank You to Jon S For This Useful Post:
07-12-2011 #2
There is one pin on the PSU which acts as an enable. Perhaps try measuring the voltages from the PSU to verify that none of them are outside tolerances, just in case?
I had an old computer recently that did what you described. Turns out it was the processor than had died.
Why would anyone do that.
07-12-2011 #3
07-12-2011 #4
Plasma cutting fault diagnoses....
By Davek0974 in forum Plasma Table MachinesReplies: 15Last Post: 01-04-2014, 07:04 PM -
heidenhain vrz731b fault
By p.cage in forum General ElectronicsReplies: 0Last Post: 31-01-2014, 03:56 PM -
Servo fault handling
By m_c in forum Motor Drivers & ControllersReplies: 0Last Post: 23-09-2013, 04:39 PM -
Heidenhain DRO fault
By Lancer in forum General ElectronicsReplies: 5Last Post: 29-06-2012, 09:57 AM -
Denford Triac Spindle Fault
By Sam_Smith in forum Denford MillsReplies: 5Last Post: 04-05-2011, 11:07 PM
