	09-08-2013 #1
What wattage laser cutter would I need to cut up to and no more than 8mm thick ally ? My next project will require a lot of exact same size blanks cutting out. Nothing big, maximum so far would be 140mm x 30mm. I’ve made prototypes on the CNC but it’s a hell of a lot of faffing about with re-seating and tool changes for some fairly boring shaped pieces. After watching a YouTube vid of a laser flashing through 5 cut-outs in a 5 mins I thought that might be the way to go. Also the quick engraving as I’m using flat plate was intriguing in its simplicity , no cooling or swarf is also a massive bonus.
Ralph Waldo Emerson
laser cutter/engraver rebuild build log
By gavztheouch in forum Laser Machines & BuildingReplies: 37Last Post: 10-11-2015, 05:37 PM -
Laser Cutter Operative Frome, Somerset
By Frome-laser-cutter in forum Opportunities Available & SoughtReplies: 0Last Post: 13-02-2014, 04:16 PM -
Hand held laser cutter
By Robin Hewitt in forum Tool & Tooling TechnologyReplies: 9Last Post: 24-10-2013, 06:05 PM -
Laser cutter
By John S in forum Laser Machines & BuildingReplies: 8Last Post: 02-06-2012, 02:16 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM
