Thread: Laser diode module machine addon
For the people that are interested in buying a laser for their CNC (add on)
this has been recommended
http://www.ebay.co.uk/itm/1206188519...ht_2977wt_1163
and here is a copy of the email sent to me
hi
thank you for your interesting in our product.
if you only cut paper card, a 3.2w laser is ok. if you cut vinyl card less than 4mm, I recommend this one for you: 120618851945 or this one: 110757351582, 980nm get better spec than the 808nm one
hope my answer is helpful. if you have any question please feel free to let me know
with best regards
Merry
- laserlands
James
10-12-2011 #2
Why would you buy one of these over a 35 or 40W tube that is supplied as a spare for the desktop machines ?
Genuine query as I'm looking at maybe getting some form of laser for marking a job that may come up.John S -
10-12-2011 #3
I have no idea as you could do so much more with 40W for less money (£280). That seems really expensive for only a 4W laser. I guess it's a bit easier to set up than the CO2 lasers.
http://www.ebay.co.uk/itm/40W-CO2-La...ht_2791wt_1270
I'd quite like one, but I don't tend to do much with plastics so I don't know how much I would use it.
10-12-2011 #4
Shopping terms:
> 1mw laser may be confiscated by UK, AU customs. Over 5mw are banned in some countries, please read your laws before place the order. We are not responsible for the customs hold or law violation.
BTW What do you need to upgrade route?
-laser tube
-power supply
-mirrors
-focus lens
-water pump for cooling
Is there something else I missed ?????????
10-12-2011 #5
I got a 40W laser engraving machine from ebay.
Cost me £129 plus Shipping.
I dont know how they can make them for that money, and it looks quite good.
Looking at using it for cutting acrylic, but may get a larger 100W machine as wellVisit Us: www.automationshop.co.uk
10-12-2011 #6
Gary if you decide to sell it please send me a email
James
10-12-2011 #7
Wiatroda,
adjustable mirror block for each mirror, adjustable lens holder for setting the centre hole of the nozzle to the beam path. Flight tubes to enclose the beam path. Safety glasses to suit the power and wavelength of the beam. Possibly a polycarbonate enclosure to surround the cutting head to absorb any stray or reflected beams.
You might want to enquire about the lifespan of the glassware. Our 3KW CO2 glassware is rated for 12000 hours but it costs loads. I dont think the cheap stuff will last very long.
Ian
10-12-2011 #8
Thanks Ian
I think they mentioned 4000hrs, but I believe power output decrease constantly towards end of life span, so I assume at 3000hrs it can be 80% or less. I read on some forum european made 100w cuts better chinese 100W tube. I don't know how it's possible ,but that's what people said from experience.
11-12-2011 #9
4000 hours is really good for that cost. Even at the end of its lifespan 80% is still good and dropping the cutting speed should still give a good cut.
Ian
11-12-2011 #10
I bet as a hobbyist to reach 4000hrs can take ages.
Just wonder how to make laser to cut under mach3 with different power. laser power supply adjusts the power by PWM modulation of ttl signal.
So if I understand correctly, if I set up different spindle speeds for different paths there is a way to control laser power output. As I never controlled spindle speed under mach3 I have very vague idea about it.
Laser Machine Eye protection
By Want2build1 in forum Laser Machines & BuildingReplies: 11Last Post: 19-05-2014, 01:46 PM -
eBay: Kress 1050 FME router with collets & 43mm mount with laser diode
By Tom in forum Items On eBay UKReplies: 0Last Post: 12-11-2013, 09:31 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
Laser Diode Constant Current Driver
By Mad Professor in forum General ElectronicsReplies: 8Last Post: 21-07-2010, 06:01 PM -
Any good low cost laser module?
By donkeyot in forum General ElectronicsReplies: 3Last Post: 23-05-2009, 03:49 PM
