Thread: slaved stepper problems
Jonathan,
the motor will run quieter at a lower voltage, this is typical with stepper motors.
also you are running the 752 at 70V, this is the absolute maximum for this driver.
I would advise to run it at a lower voltage.
60V is a good voltage with the SY60.
As i mentioned before the problem is not with the driver but the 3V is too low.
I come across this a lot when people are using the parallel port.
It is a very cheap and simple 5 minute fix.Visit Us: www.automationshop.co.uk
07-01-2012 #2
I am running it directly from the parallel port.
I suspected that, was just interested in checking the theory!
I would advise myself that too, however I've checked it by connecting my oscilloscope to the MOSFETs (IRF540) whilst running and measuring the peak voltages at the points where it they switch under various conditions. There are no peaks above the rating of the MOSFETs, which is 100V, so I'm happy that it's safe.
That's no reason for anyone else to do the same, since each system will vary.
It looks like it must be the low voltage of your parallel port, but that still doesn't explain why the driver wouldn't work from the same pins on the parallel port that the other drivers worked with.
tree problems!
By kingcreaky in forum Woodwork DiscussionReplies: 8Last Post: 02-06-2014, 12:35 PM -
Mach3 PC problems, help please....
By Davek0974 in forum Plasma Table MachinesReplies: 13Last Post: 30-01-2014, 07:05 PM -
F-Engrave problems
By cropwell in forum CAD & CAM SoftwareReplies: 29Last Post: 29-06-2013, 03:48 PM -
problems since update
By motoxy in forum General DiscussionReplies: 6Last Post: 02-11-2012, 06:14 PM -
NEW MEMBER: MDF Problems
By MrWiz73 in forum New Member IntroductionsReplies: 4Last Post: 31-12-2011, 12:39 AM
