Thread: slaved stepper problems
07-01-2012 #11
I've now tested your driver. I connected it up in place of my Y-axis driver. I use *752 series drivers, so they're on 70 volts hence I used a lab PSU set to 48V for your driver. It works fine... I've not done anything to it, just connected it and changed the switches to 1600 step/rev as that's what I use. Then tested it on 800 and 400, not really expecting that to make a difference, and it didn't.
Interestingly the motor runs more quietly and possibly more smoothly (difficult to tell of course) with your driver. I'll have to test my own driver on 48V to see if it's just the lower voltage causing that. If not then that's useful information as it implies they use different control algorithms. As expected though the feedrate I can get with 48V is less (24000mm/min @ 2000mm/s/s acceleration) but still plenty!
So what would you like me to do now? Just send it back and hope it starts working on yours too? I'll have a look inside anyway just to be sure.
tree problems!
By kingcreaky in forum Woodwork DiscussionReplies: 8Last Post: 02-06-2014, 12:35 PM -
Mach3 PC problems, help please....
By Davek0974 in forum Plasma Table MachinesReplies: 13Last Post: 30-01-2014, 07:05 PM -
F-Engrave problems
By cropwell in forum CAD & CAM SoftwareReplies: 29Last Post: 29-06-2013, 03:48 PM -
problems since update
By motoxy in forum General DiscussionReplies: 6Last Post: 02-11-2012, 06:14 PM -
NEW MEMBER: MDF Problems
By MrWiz73 in forum New Member IntroductionsReplies: 4Last Post: 31-12-2011, 12:39 AM
