Thread: slaved stepper problems
07-01-2012 #21
Have you slaved it in mach3, so the drivers are connected to seperate pins (4 in total) of the parallel port, or is it one step/dir signal going to two drivers in parallel? If it's the latter that would explain it as the parallel port can't source much current, so with two drivers the voltage will drop.
08-01-2012 #22
yes as jonathan has said, putting one output in parallel is not a good idea.
if it has its own output from the parallel port than it is just down to tollerance.
the driver that has the problems is just slighly out of spec or the others just have a higher tollerance.
just power the opto up with a good +5V and problem solved.
Or get a breakout board that buffers the outputs.
Simples...Visit Us: www.automationshop.co.uk
08-01-2012 #23
yes it is slaved in mach3
11-07-2012 #24
I know I'm late coming in with this but if you really must run the same axis on two stepper motors I'd be inclined to ensure they are identical bipolar type and connect them in series.
tree problems!
By kingcreaky in forum Woodwork DiscussionReplies: 8Last Post: 02-06-2014, 12:35 PM -
Mach3 PC problems, help please....
By Davek0974 in forum Plasma Table MachinesReplies: 13Last Post: 30-01-2014, 07:05 PM -
F-Engrave problems
By cropwell in forum CAD & CAM SoftwareReplies: 29Last Post: 29-06-2013, 03:48 PM -
problems since update
By motoxy in forum General DiscussionReplies: 6Last Post: 02-11-2012, 06:14 PM -
NEW MEMBER: MDF Problems
By MrWiz73 in forum New Member IntroductionsReplies: 4Last Post: 31-12-2011, 12:39 AM
