  1. Good day all.
    I am trying to find a new key for my chuck, but I don't know where to start.
    All the standard chuck keys I have are way to small for this chuck.
    Here are all the details stamped on the chuck.
    Cardinal Mk II
    Pat No 651588
    D
    1/2"
    No33 Taper
    CA12
    Thanks for your time.
    "If first you don't succeed, redefine success"
    Measure the size of the (probably) square hole in the chuck for the key, then you should be able to find one to fit. If not I can make one.
    This may help? The chap modified a K4 Jacobs chuck key for his MT3 tapered drill chuck. Looking at though you may get away with a 16mm chuck key?
    http://www.practicalmachinist.com/vb...-3-4-a-172002/
    Or contact these for the spec, the manufactured the cardinal many years ago :tup:
    BROOKE CUTTING TOOLS (UK) LTD
    • ALL ENQUIRIES-MAIN SWITCHBOARD, HELLABY IND EST, DENBY WY, HELLABY, ROTHERHAM
      S66 8HU ROTHERHAM , SOUTH YORKSHIRE
      Phone : 01709 314500
      Fax : 01709 314501
      E-mail : Send messagewww.brooke.co.uk
    I should have noticed from the original post that it's a drill chuck, not a lathe chuck .
    I have a 1/2" cardinal chuck, it's physically the same size as the 1/2" jacobs chucks
    I have and uses the same key. I think the jacobs are type 34. I will write down the key
    number and measure the diameter tomorrow.
  7. graffian: did you have any luck finding out any details regarding the key?
    The chuck pilot hole seems to be 5/16 [0.3125"] (7.9375mm).
    Yes I had a look, I couldn't find the cardinal chuck but the key I use on jacobs 34 chucks came with the
    cardinal chuck. The key has a 5/16 pin and 11 teeth. The key I have is a jacobs and just has
    a 3 on it, but it goes with 34 chucks so it shouldn't be a problem finding one.
    The next size down key I have, which is for jacobs 32 chucks, has a 1/4 pin and 9 teeth.
    The next size has a .375pin and 12 teeth, that is for the jacobs 36 chuck.
    New to this forum so somebody may be able to help. My primary interest is Woodturning but I have a Myford ml 7 as well. I recently got a Meddings MB4 mark 2 drill , very dirty and uncared for but all parts in good order. Everything now back 'as new' except chuck.
    It had a Cardinal mark 2 chuck which needs to be disassembled and cleaned. Does anyone have any idea how to do this. On the back of the chuck there is a series of small holes in a circle. Not sure whether it can be 'drifted' apart or if there are threads in there somewhere.
    Here are some photos
Name:	File 22-01-2017, 16 12 27.jpg
ID:	20452Click image for larger version.
Name:	File 22-01-2017, 16 12 47.jpg
  1. WANTED: 80mm lathe chuck, 3 or 4 jaw
    By Jonathan in forum Items Wanted
    Last Post: 07-03-2013, 01:04 PM
  2. WANTED: collet chuck
    By Miniman in forum Items Wanted
    Last Post: 13-12-2012, 05:26 PM
  3. WANTED: 4 jaw chuck Boxford - Axminster etc
    By Fivetide in forum Items Wanted
    Last Post: 05-10-2012, 08:45 PM
  4. I'm not self centered chuck
    By GeorgeD in forum Milling Machines, Builds & Conversions
    Last Post: 28-07-2010, 08:20 PM
  5. What Collet Chuck have I got?
    By irving2008 in forum Tool & Tooling Technology
    Last Post: 24-11-2008, 08:41 AM
