25-12-2011 #8
There's no need to auto probe to get the cnc machine to find the SMD pad centre , my pcb software can either give me those coordinates or I can export the smd pad as a gerber file & import into a cad program & get the cad software to mark the centres of each SMD pad. (which I can then use cam software to use this coords with)
Ok so using this brain melarkey....my z plane lowers & once at say 0.2mm, a trigger happens....but what is the output here? Mach 3 has control of the printer port, presumably once the 0.2mm threshold is breached a nominated pin will change state?
mounting profile rail - Hiwin Manual vs. typical approach
By dsc in forum Rails, Guideways & BearingsReplies: 14Last Post: 11-12-2013, 10:43 AM
