30-12-2011 #20
Thanks routercnc for the spreadsheet and the comment re the X axis bearing placement. I've seen them placed like this on another design, but somehow felt that vertical placement would be better for carring the vertical weight of the gantry and resisting racking. For the gantry I will be using 20mm plate sides with 120x40mm heavy extrusion (8.8 kg/m) for the y-axis on the basis that the box section resists twisting from the cutting loads better than plate and is lighter, reducing the forces required to accelerate and stop the gantry.
BTW I too am a model flyer (Gliders and power) and have in mind to build a 1:3.5 scale (4.25m) "Reheinland" glider with all the bits CNC cut - once I have done my brother's guitars!
Kind Regards
Mike
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM -
