We are looking at getting a CNC (8' x 4') router, we are going to be cutting 9mm birch panels.
I am just designing a Vacuum Table system to allow us to have 6+ vacuum sections on the bed, i found a great tutorial from a US source.
The question i have .. if using 50mm piping to create the vac distribution system under the table with cut off valves for each section. What grade of piping and valves should i be looking at?
Many Thanks!
James
08-01-2012 #2
No personal experience but a place I visited some time ago used solvent welded waste water pipe. Sorry but I never noticed the valves.
16-01-2012 #3
I would have thought any grade of piping would do, so long as it is rigid. If you produce a perfect vacuum you will have an external pressure on the pipework of 1 bar. This is minimal compared to the internal pressure that most pipes take. Class C pcv pipe will take an internal pressure of 9 bar for example.
16-01-2012 #4
16-01-2012 #5
I want a vacuum table!
By Tenson in forum Machine DiscussionReplies: 44Last Post: 08-01-2014, 07:40 PM -
vacuum table using compressed air
By plasticman in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 25-12-2012, 05:42 PM -
Vacuum Table Advice
By Minium in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 13-11-2012, 09:52 AM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
