    Is there room in the design for two diagonal stretchers from corner to corner ?
    I think so...
    It's common to fix them to the floor, but not the wall. I think it's a good idea to fix it to the wall too so long as you can do it without distorting the frame. The wall is obviously very strong so if the frame is fixed to the 2 walls at a few points you've immediately made it significantly stronger, in addition to stopping it moving.
    But why is it moving should be a question.? . . . Is it just the inertial movement from stopping etc while fast jogging or is it from vibration.?
    If it's inertial then it's simply the lack of mass but if it's vibrating or shacking from miss aliagnment then you need to find the cause because even if it's fastened to the wall floor while it won't walk around the floor it will still resonate and show in the finished cut. . . . It will also destroy it's self in a short amount of time if too bad.
    It's not uncommon for small or light framed machines to walk around while rapid jogging so nearly always need bolting down. Even my steel framed machine is bolted down.
    It's moving due to the acceleration / deceleration, i.e. when it changes direction rapidly. We tried the 'Bulls Head' test sign in Vcarve which dots around a lot...
    I doubt it's a problem of misalignment. All the slides are very smooth.
  1. Do I need to insulate a shed floor?
    By Philly in forum Workshop & Equipment
    Last Post: 06-06-2014, 07:33 AM
  2. Fixing linear rail - DIY practice
    By CharlesJenkinson in forum Rails, Guideways & Bearings
    Last Post: 10-02-2014, 12:53 PM
  3. wall cnc like the wall saw
    By crossleymarko in forum Machine Discussion
    Last Post: 25-03-2012, 11:24 AM
  4. Reading and fixing Chinese scales
    By irving2008 in forum Tool & Tooling Technology
    Last Post: 24-02-2010, 10:35 PM
  5. CNC Wall art from JPG
    By BJ- in forum Opportunities Available & Sought
    Last Post: 29-01-2010, 03:06 PM
