Thread: MDF Problems
30-12-2011 #1
Hi everyone. I have sourced and cut various makes of MDF now and i am having the same problem with all of them, and that is the edges are furring quite badly. Is there a type of MDF i can use that leaves nice crisp edges? I need to stock 4, 6, 9, 12 and 18mm. I am aware that spindle speeds etc can cause the furring but have also tried slowing right down and speeding up to try and get round this...but no joy. I have used a straigh twin flute bit and a single flute upward spiral but am getting the same results. I am fairly new to CNC and everthing i do is a bit trial and error but need to get this sorted. Can anyone help me?....please? :) Sean
30-12-2011 #2
Is it because you are using damp MDF?
James
30-12-2011 #3
What speeds & feeds DOC are you using or have used.?
30-12-2011 #4
Try MR MDF
31-12-2011 #5
Erm, if I'm interpreting what appears to be an oxymoron correctly you tried increasing the spindle speed and reducing the feed rate, or vice versa? For MDF you want quite a high chipload, so a relatively low spindle speed with a high feerate. The swarf should look like chips not dust. If it's dust the cutter will not last long at all.
tree problems!
By kingcreaky in forum Woodwork DiscussionReplies: 8Last Post: 02-06-2014, 12:35 PM -
Mach3 PC problems, help please....
By Davek0974 in forum Plasma Table MachinesReplies: 13Last Post: 30-01-2014, 07:05 PM -
F-Engrave problems
By cropwell in forum CAD & CAM SoftwareReplies: 29Last Post: 29-06-2013, 03:48 PM -
problems since update
By motoxy in forum General DiscussionReplies: 6Last Post: 02-11-2012, 06:14 PM -
Spindle motor problems
By geoffby in forum Motor Drivers & ControllersReplies: 11Last Post: 07-11-2010, 08:25 PM
