Thread: Clock on going project
Inkscape I think can do it and I believe it can export into dxf. Might want to look there and is free. Which Punch did you get as one or 2 of them can import jpeg/bitmap as well.
Michael
03-01-2012 #2
James if you can scan the images then I can convert to vectors and save as DXf or striaght to g-code if you want.?
Edit: Can knock you something up using this dragon relief if you want.? . . .Just tell me size and shape of top plus depth of emboss.
I also v-carved the red welsh dragon into the back of aztec calender ounce and that looked good, if you want DXF then I can extract the vectors for you. If you want V-carve then I need to know sizes etc.
Edit 2:Found model of v-carve to show.! (silver pics)Last edited by JAZZCNC; 03-01-2012 at 02:10 AM.
high council of the time lords - diy wooden clock
By kingcreaky in forum Woodworking Project ShowcaseReplies: 7Last Post: 13-03-2013, 11:01 PM -
RFQ: CNC cut discs and clock hands required
By Markz in forum Projects, Jobs & RequestsReplies: 0Last Post: 01-02-2013, 05:23 PM -
A grasshopper escapement based clock project
By pcstru in forum Woodworking Project ShowcaseReplies: 4Last Post: 18-07-2012, 02:48 PM
