10-01-2012 #2
10-01-2012 #3
Pen & paper is just as good if thats all you have, you don't need to be Norman Foster just have the abilty to draw lines and arc's to scale. Also think you'll actually find if you don't have any experience with Cad then it will probably be quicker.!! . . . . Thou you are going to have to learn Cad at some point because without it a CNC machine is pritty useless.:rofl:
If you draw it 1:1 scale then you can use the drawings as templates for cutting and drilling.
Can't stress how much easier it makes things having a good drawing, it doesn't need to be drawn to the very last detail but with key parts like Z axis then it really does help. . . . If you have plenty of money and can afford the "Cut it & see" route then go for it, other wise get drawing to save money.
Ask if your not sure and need guideance but nobodys going to say you need exactly this length rail or this length screw because unless your copying there design exactly then really it's not possible.!
At the very least you will have to give some idea of your want's and needs. IE Desired cutting area, Z travel, rail type, screw type etc.
I'm more than willing to help you come to the final design for a machine, even help with cutting parts etc and I'm sure there will be others like Jonathan willing to make usefull helpfull suggestions but ultimately it's down to you and you that needs come too and understand the final design and components needed because your building it.! . . . . Nobodys likely going to do it ALL for you fully without plenty of beer tokens changing hands. (Unless your have 5'8" blonde nympo sister that likes fat bald yorkshire puddings.?? . . .In that case I'll be down shortly with the machine. .:rofl:)
Get drawing then asking and don't buy or cut a thing untill your sure.!!
3d AutoCad CNC machine parts.
By jcb121 in forum Open Source Designs & PlansReplies: 1Last Post: 09-10-2014, 10:18 PM -
Time for a new machine - need help!
By Isaac in forum Machine DiscussionReplies: 7Last Post: 19-05-2014, 02:04 AM -
Does anyone tell me the main parts of CNC Milling Machine?
By hoezap in forum General DiscussionReplies: 0Last Post: 07-11-2011, 01:25 AM -
Machine rebuild time - options...
By CraftyGeek in forum Gantry/Router Machines & BuildingReplies: 28Last Post: 19-10-2011, 10:26 PM
