Dean regards dimensions Gantry width, Y Axis etc then you want to get the dimensions of the actual bearings your going to use, these will dictate the minium width.
Also if you are planning on using ballscrews the chances are you will use BK/BF bearing blocks to mount the screws, these along with rail/bearing width will dictate the Z axis minimum width.
If you look around on the net there will be 3D models of BK/BF Blocks, linear rail/bearings etc these make it easier and save some work.
Try to model it close to spec of parts to be used as possible, this becomes more important in areas where it gets tight like the Z axis. It's very easy to think it will fit then find out it doesn't by a few mm's.!!!
3d AutoCad CNC machine parts.
By jcb121 in forum Open Source Designs & PlansReplies: 1Last Post: 09-10-2014, 10:18 PM -
Time for a new machine - need help!
By Isaac in forum Machine DiscussionReplies: 7Last Post: 19-05-2014, 02:04 AM -
Does anyone tell me the main parts of CNC Milling Machine?
By hoezap in forum General DiscussionReplies: 0Last Post: 07-11-2011, 01:25 AM -
Machine rebuild time - options...
By CraftyGeek in forum Gantry/Router Machines & BuildingReplies: 28Last Post: 19-10-2011, 10:26 PM
