Page 1 of 16 12311 ... LastLast
    Hi guys. This is my first attempt at building anything like this myself. I have a history in motorcycles for 45 years and used to be a mech eng designer. Its a bit diferant without a full blown workshop doing your bidding. This project has a limitation on funds but I will not skimp if possible.
    As it is the first I have decided to make a torsion box base. If this all works then I can upgade to a metal frame later. I also thought that linear rail bearings would be better than bearings on angles.
    I realise that regidity is essential so the y gantry has been constructed from 10mm Ally. Although it came cheap the angle was not exactly 90deg . Bit of patience and it appears to be fairly accurate. When the rails arrive for it the will be measured off the x rails to locate. If it ends up being too heavy then I can cut sections out to lighten the load. It rolls well but inertia maybe a problem.
    I have ordered ballscrew, 2 for the x and 1 for the y. My next decision is stepper size (3nm maybe) and whether to build or buy the z.
    Comments are always welcome. Already had great advice on spindle choice.
    Bruce
ID:	5160   Click image for larger version.
ID:	5161   Click image for larger version.
ID:	5162   Click image for larger version.
ID:	5163   Click image for larger version.
    I too started with my X-axis rails mounted to a torsion box made from MDF/pine with a gap left either side to hide the 2 leadscrews. I'm still using the torsion box as the machine bed. Making the steel frame for mine made a huge difference. What size are your X-axis rails, they look like only SBR16 or 20mm?
    Plate is weak for the gantry since when the machine is cutting parallel to X the cutting force will try and bend the gantry, and that's in the direction that's worst for a rectangular cross section. It's also the worst cross section to choose for twisting. Adding extrusion, or more plate perpendicular to it to the back would help, but you could try it and see and make sure you leave space to add it at a later date if required. What is the width of the plate, so I can calculate the deflection (roughly)?
    I'd be inclined to add some triangular pieces to the aluminium angle to stop that flexing.
    3nm is a good choice for the stepper motors. Lots of people, including me, use them. If you can afford 70 volt drivers (like MDS752) then you will get a higher feedrate than 50V (like MDS542), but it's more difficult/expensive to find/make a suitable power supply. The mass/inertia of the gantry is not a problem with these motors. Chip's and mine (and many others) using the same motors weigh a lot more.
    Have you bought the ballscrews yet? If not then get 10mm pitch (RM1610) for X/Y to get a higher feedrate and use HTD timing pulleys (although 1:1 ratio is about right for those motors and 10mm pitch screws adding the pulleys still helps as it reduces resonance). 5mm pitch screws (RM1605) will work but it wont go anywhere near as fast, or more importantly the acceleration will be less and possibly vibrate more as the screw is spinning twice as fast.
    Thanks for the heads up guys. All the material is 10 mm thick and 150mm wide. I had wondered about the the plate for the gantry but thought I could add box/angle to the back if required. the rails are 16mm
    Unfortunately I have already ordered the lead screws and they are rm1605. I really should ask first DOH!. I am going to look into ordering the motors controllers this week sometime.
    The angles on the rails were left hanging for, just as you say, the support for the nut on each side. I also thought that this allowed for the Y screw supports to be further apart and thus allowing me to use more of the bed width.
    I really appreciate all your help guys
    Bruce
    x and y screws plus the y rails arrived today. Had a thought about the gantry design and have to agre especially with the angle on the rails. Looks like a bit of a rebuild required. I will also have to think about the z gantry.
    Jonathan
    He is using an MDF box and i think the screws he has ordered are much more suitable, you need to stop pressing everyone with the need for speed? shake rattle and role will not bode well here.
    Bruce your screws will be just fine for the application you have there.
    Quote Originally Posted by 2e0poz View Post
    So was I, and I am now though it's no longer there for strength. To start with that will be a limiting factor, but there's always the option to add a steel frame ... or even a simple rectangle on the bed made from steel box would help a lot.
    That's why I mentioned you'll get better *acceleration* with 10mm pitch screws, and less vibration from the screw as it's not spinning so fast. I agree high rapid speeds are pretty much useless, but good acceleration is important. When I cut the mayan calender using lower aceleration values (as I was limited by the computer) than Jazz did added over an hour to the time it took. That's quite an extreme example admittedly, but the general trend is true.
    Yes they will work fine, but not as well as could have been.
    The problem is every time you mention 1610 screws it makes it sound like everybody has to rush out and buy them?????? just remember to when you first started mister and how difficult it was. I use 1605 screws and belts on mine and it is more than enough for it's job, i could have my X axis twice as fast as yours with the belt but it would be pointless.
    Thats it my rant is over and i'm stepping back from the computer for a cup of tea.
    In my opinion 1605 has very few advantages over 1610 for a router, which is why I recommend it so often.
    When I was designing my router, the rotating ballnut design was far more difficult that picking the ballscrew, but that's just my opinion.
    Even if you manage to get 60m/min, it will only be for a short time before failure. Realistically it's impossible. In terms of speed and acceleration 1610 screws outperform 1605 by a large margin. Even hypothetically running a 1605 at 2:1 is still inferior in performance to a 1610 at 1:1 due to higher K.E.
    I started with a 2mm pitch screw on Y and 2.5mm on X since that was the biggest I could afford at the time (not ballscrews), and I made a rotating nut for X to compensate and that funny wonky bearing drive, that I wish there was a simple name for, on Y to lower the friction.
    Ok can't resist got to jump in.!!!:twisted: . . . Don't need to worry about 5mm pitch being inferior because of K:E bull shit etc because it don't mean jack shit for a DIY machine, it will still perform more than good enough.! . . ( If built good enough.!!)
    Yes jonathan's correct when he points out that the calculated physics way of looking at it that 10mm pitch wins for a router!. . . BUT. . . I can tell you because my machine use's 5mm pitch geared 2:1 it's absolutly no problem and in no way limits the performance. Actually IMO it's a bennifit because it's just a simple belt/pulley change to gain resolution.
    That said I agree that 10mm pitch (except Z axis then 5mm) would be better choice for a router which mainly cuts wood or plastics. Anything harder IE Ali etc and then extra speed 10mm pitch gains is wasted as the feed rates dictate. 99.9% of the time you'll be lucky to cut any where near quarter the speed 10mm pitch allows.!
    An often over looked and misunderstood area which Jonathan touched upon earlier is acceleration.!! . . . IMO and experience for most jobs (Esp 3D) that don't need high feeds (2mtr/min or less) then your much better off tuning your motors to give higher accel than velocity. . . Often less is more.. . Like in the Aztec case where there are lots of short moves it can and does often make job's faster. 3D and v-carving really see the most increase's from high accelleration.
    I use Mach3 and it's such a simple job to create profiles that you can easily tailor for specific job types or conditions. IE I have 3D profile tuned for Accelleration. 5mm pitch profile (pulley/belt change)for when resolution needed. I also have profiles for Inch units for each so when I get given code that use's imperial measurements I don't have to fanny about changing settings or code.
    Doing it this way makes it very simple and quick to change from one to the other.
    So Like 2eOpoz I 100% agree 5mm pitch will be fine in your case.!. . . . BUT . . . 100% Agree with jonathan 10mm pitch rules for a wood/plastic router.
    Anyway the screw pitch or speed will be the least of your troubles if you don't beef that gantry up.!!
    Don't need to worry about being inferior because of K:E bull shit
    I think you'll find just about everyone apart from you agrees kinetic energy isn't 'bull shit' and is very important, I'm not even going to argue this point because it's so widely accepted. No matter if a machine is made in a home workshop or professionally, it can't escape the laws of physics. A 3nm Nema 34 motor wont go as fast as a 3nm Nema 23, it's due to exactly the same calculation!
    As far as I'm aware you've not tried 10mm pitch rails on your router, so I can't see how you could possibly know that. I'm well aware that you don't respect calculation, and that might well be true for you, but for just about everyone else, calculation plays a hugely important role, and if it didn't work like you say, the theory simply wouldn't be there.
    That clearly also applies to 1610 so it's not a benefit. Since you only recognise empirical evidence, your version of the Mayan calender I cut on 1:1 looks amazing.
    It's not about cutting faster, it's the acceleration gain from using 10mm pitch that's most important. You told me your acceleration on the Y-axis is 900mm/s/s, with 5mm pitch. I now have mine set to 2000mm/s/s with 10mm pitch (more shakes the machine too much).
    I get the impression you think I'm saying 5mm pitch won't work, seeing as you say "it will work fine". I agree with that, but when designing a machine I think it's foolish to aim for it working fine, you should aim for it to work as well as possible, not just well enough and 5mm pitch screws will simply limit the potential of your machine.
    I'm not going to say anything more on the subject since apparently it provokes a particularly strong reaction, I think motoxy has all the info to make an educated decision. Good luck.
    Motoxy: There's a quote for that - The more I know, I know, I know the less. (John Owen)
  1. BUILD LOG: Scrap Heap Challenge
    By TrickyCNC in forum DIY Router Build Logs
    Last Post: 16-09-2012, 07:52 AM
  2. NEW MEMBER: Up for a challenge......
    By swatt in forum New Member Introductions
    Last Post: 03-10-2010, 10:57 PM
  3. Fancy a challenge?
    By cassius in forum Machine Discussion
    Last Post: 03-09-2010, 02:44 PM
