Page 4 of 16 FirstFirst ... 2345614 ... LastLast
  1. #31
    Hi Jonathan
    I am beginning to see where your coming from. I have taken on board previous comment about the over hang over the x rails. At the moment their 700mm but I could reduce this to 600. I am going in on monday to see what box is available.I thought about 80 x 40 with the rails top and bottom.
    Bruce
    The more I know, I know, I know the less. (John Owen)
  2. #32
    Quote Originally Posted by motoxy View Post
    80x40x3 box section is less than a third as torsionally stiff as an 80x80x3 box section. Same reason as before - material is distributed further from the centroid with a square compared to a rectangle.
    These photos show mine (old pictures!) with the size I mentioned. I put 20mm thick plate in the ends of the box section to make as strong joint.
ID:	5176Click image for larger version.
  3. #33
    emmm. okay. I have looked on line and 3" x 3" x 10 swg (3.2mm) is easily available. My limitation is no access to a mill. All my work is bench work. But I am sure I can come up with something.
    I feel I have come a long way since i started reading the site where someone was building a plywood cnc on his kitchen table. I have t admit that I am glad to be getting so much advice that does make sense.....so far
    BTW I have made an offer on the spindle. See if he bites???
    Jonathan may I ask what you are studying at uni?
    Bruce
    closing off see you all tomorrow some time.
  4. #34
    See your mum was right? there was reason why she said to eat up your weetabix in the morning:whistling:
  5. #35
    Electrical engineering.
    Quote Originally Posted by 2e0poz View Post
    Er, who was that aimed at - I don't follow?
  6. #36
    Cereal packet - Weetabix........Bruce
  7. #37
    Dear mum, bless her
  8. #38
    Just ordered my spindle and inverter. Made an offer of £140 instead of £172 and it was accepted:dance: Other than postage that makes it the same price as a Kress. Bargain.
    Now off to redesign the gantry.
    Bruce
  9. #39
    Yup
    Here is the item no. 190618666009
    There are more to be had
    Bruce
  10. #40
    OK Here is a thought on redesigning the gantry. Any similarity to Jonathan's machine is purely down to plagerism. I have looked at a construction that I can do myself. I will make some enquiries tomorrow about acccess to a m/c shop.
Name:	redesigned gantry 1.jpg
ID:	5180Click image for larger version.
Name:	redesigned gantry 2.jpg
ID:	5181Click image for larger version.
Name:	redesigned gantry 3.jpg
  1. BUILD LOG: Scrap Heap Challenge
    By TrickyCNC in forum DIY Router Build Logs
    Last Post: 16-09-2012, 07:52 AM
  2. NEW MEMBER: Up for a challenge......
    By swatt in forum New Member Introductions
    Last Post: 03-10-2010, 10:57 PM
  3. Fancy a challenge?
    By cassius in forum Machine Discussion
    Last Post: 03-09-2010, 02:44 PM
