    Hi Jonathan
    I am beginning to see where your coming from. I have taken on board previous comment about the over hang over the x rails. At the moment their 700mm but I could reduce this to 600. I am going in on monday to see what box is available.I thought about 80 x 40 with the rails top and bottom.
    Bruce
    The more I know, I know, I know the less. (John Owen)
    Quote Originally Posted by motoxy View Post
    80x40x3 box section is less than a third as torsionally stiff as an 80x80x3 box section. Same reason as before - material is distributed further from the centroid with a square compared to a rectangle.
    These photos show mine (old pictures!) with the size I mentioned. I put 20mm thick plate in the ends of the box section to make as strong joint.
ID:	5176Click image for larger version.
    emmm. okay. I have looked on line and 3" x 3" x 10 swg (3.2mm) is easily available. My limitation is no access to a mill. All my work is bench work. But I am sure I can come up with something.
    I feel I have come a long way since i started reading the site where someone was building a plywood cnc on his kitchen table. I have t admit that I am glad to be getting so much advice that does make sense.....so far
    BTW I have made an offer on the spindle. See if he bites???
    Jonathan may I ask what you are studying at uni?
    Bruce
    closing off see you all tomorrow some time.
    See your mum was right? there was reason why she said to eat up your weetabix in the morning:whistling:
    Electrical engineering.
    Quote Originally Posted by 2e0poz View Post
    Er, who was that aimed at - I don't follow?
    Cereal packet - Weetabix........Bruce
    Dear mum, bless her
  1. BUILD LOG: Scrap Heap Challenge
    By TrickyCNC in forum DIY Router Build Logs
    Last Post: 16-09-2012, 07:52 AM
  2. NEW MEMBER: Up for a challenge......
    By swatt in forum New Member Introductions
    Last Post: 03-10-2010, 10:57 PM
  3. Fancy a challenge?
    By cassius in forum Machine Discussion
    Last Post: 03-09-2010, 02:44 PM
