14-01-2012 #2
Funny that, I never noticed the Nissan before. Guess I couldn't see the wood for the trees :lol:
A few beers in me now, but I can only count eight wires from each motor. Would that still make the Heiz controller dodgy?
Cheers,
Gavin
14-01-2012 #3
Gavin if you wanted to just run the machine and check motors etc then the Heiz controller would probably work ok just don't push the motors to hard. There's only 0.2a difference and it's very unlikely you'll come near that just jogging it around. Just make sure the Heiz is set for parallel wired motors.
14-01-2012 #4
14-01-2012 #5
Thanks guys :tup:
I wasn't sure where you were getting the 2.4A/phase from but I see it now. I think the Heiz controller is 500 Euro + delivery & I see on the website they state the phase current as up to 2.1A. Maybe I'd be better spending the money in a different way.
I'll pull the machine out in the garage to get some good light & take a video of the controllers. I'll also contact ITT/Burny again & ask them to send me the spec. sheets for the driver board, as surely that has to be standard. Initially they told me that they wouldn't be of use to me as HME wrote their own software, but I now understand that must be for the HPGL board. I'm looking forward to ripping that one out :naughty:
If mating breakout to the driver was going to be difficult, would I be better with something like this?
http://www.ebay.co.uk/itm/CNC-Router...item1c222cd4bf
or this?
http://www.routoutcnc.com/lpkits.htmlLast edited by artmin; 14-01-2012 at 11:25 AM.
14-01-2012 #6
The first link, M542 drivers, is ideal. Not sure if it's the cheapest - just look for 3 drivers with 542 in the part number and a suitable breakout board and you'll be fine.
The second link is pretty poor as the driver only goes up to 30V and the motor torque (and therefore feedrate) is proportional to the applied voltage. Plus you'd be running very close to the maximum current for those drivers.
Again if you can check the rectified voltage from the transformer with a multimeter and it's less than 50V, but significantly less then you can keep it as long as it can deliver enough power. Could you measure the diameter and height of the transformer so we can estimate the output current?
The Following User Says Thank You to Jonathan For This Useful Post:
14-01-2012 #7
I pulled the transformer out of the panel hoping to find some specs. printed on it, but unfortunately nothing.
It turns out to be Lintron & from there website I have the following specs: 160VA with an OD of 115 & height of 45. Weight 2Kg
The AMC driver board has +37VD printed on it beside a fuse along with +5VD in other places, so I'd guess a tapped voltage of +37V. Current I don't know.
I'm starting to think that as I'm not 100% sure what I'm doing (more like 50/50 at the mo. :lol:) it might be best for time versus cost, to go for a one box solution.
Trawling through other parts of the forum I see Roy at DIYCNC has a good name. What about this as a 1 box solution?
http://www.diycnc.co.uk/html/cnc_systems.html The 3 axis System without motors Code SYS43CFK £252. I see the supply voltage is 27V though when the steppers will take up to 90V :confused:.
I hadn't clicked that the supply voltage was proportional to motor speed & torque. Holding torque would be more important to me than travel speed. I aim to be cutting hardwoods, MDF & plastics in this machine but I don't know what kind of torque I need. The spindle power is usually my limiting factor as I will probably install a Kress 1050 unless someone can suggest an alternative. The Kress can burn through brushes rightly with a 6mm cutter :twisted:. With the Kress speed control for me would be unimportant as I normally set it manually at the start of each process. I just need an output that I can use to switch the spindle.
21-01-2012 #8
1,3) As 2e0poz said, but probably 2.4A as bipolar parallel current is 1.4 times unipolar current.
2) No, floating is fine.
4) Do not put fuses between the PSU and the stepper drivers as a break in connection between them could damage the driver. They have internal protection, so just put a fuse on the mains input.
14-01-2012 #9
It is rather distracting.
Those motors don't have much torque (1.5Nm) for nema 34. The datasheet only mentions A and B phases and 8 wires so looks like it's 2 phase. Standard 5-phase stepper motors are 0.72° step angle, whereas this one says 1.8° which is standard for 2-phase 200 step/rev. I've got a fairly big Nema 34 stepper motor lying around somewhere. You can get stepper drivers for them on eBay, but I just made a simple unipolar drive for it and it works. Never actually used it - one day I'll make a proper bipolar drive for it. It's a good candidate for my lathe I reckon...
14-01-2012 #10
Looking for a copy of Burny/ITT WinAMC software for an AMC4 controllor/laser cutter
By whereditgo in forum Machine Control SoftwareReplies: 8Last Post: 27-10-2018, 10:29 AM -
DSP controller questions, Will this work well with Deskproto as my CAM software?
By chris in forum DeskProtoReplies: 7Last Post: 18-01-2014, 07:04 AM -
FOR SALE: SuperPID v2 (Closed-loop PID Router Speed Controller)
By Mad Professor in forum Items For SaleReplies: 18Last Post: 23-04-2013, 10:48 AM -
elu cnc 860 router software help
By willie walker in forum Machine Control SoftwareReplies: 0Last Post: 16-04-2013, 08:07 PM -
Reversed axis on a AXYZ 6010 after installing DNC controller software...
By RickyThunders in forum Machine Control SoftwareReplies: 1Last Post: 12-02-2013, 03:56 AM
