I have two strange problems...
1)I have set mine up and works somewhat. My max rpm at 400hz is 11520, though it's supposed to be 24000.
2)The external on/of switch and pot work fine at until 300hz. Over 300hz and the system becomes unresponsive to reducing the pot or switching the control off. The only way to stop the spindle is to unplug the inverter.
	14-08-2016 #2
Are you sure about the spindle speed? These inverters are often set up with the wrong parameters for the motors so that they read roughly half the speed they should. One way to check is to look at the frequency display rather than the nominal spindle speed display. I can't remember the relevant parameter number off the top of my head although there are various posts that discuss this if you Google it. Mine does the same thing - just haven't bothered to change it yet!
	14-08-2016 #3
	14-08-2016 #4
Is this what you are looking for :- http://www.mycncuk.com/threads/7388-...se-Spindle-VFD
Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
By Mad Professor in forum Spindles & Drive MotorsReplies: 34Last Post: 01-10-2016, 10:21 AM -
Help needed connecting IMO JAGUAR VFD to Orac
By asto in forum Spindles & Drive MotorsReplies: 0Last Post: 09-04-2013, 08:05 PM -
huanyang vfd 2.2 error E.CO.A
By edgas10 in forum General ElectronicsReplies: 0Last Post: 01-07-2012, 08:12 PM -
connecting stepper driver to PC
By berkut in forum General ElectronicsReplies: 2Last Post: 10-06-2009, 09:25 PM
