Thread: BV30 Lathe
12-01-2012 #4
Jonathan,
Thanks for the bellows idea, I had just been thinking about the ballscrew but bellows could help keep the ways clear as well.
I agree that it seems like a lot of work, and that just replacing the bearings would be the easy option.... but the gearbox has too much slop for index &or live axis use which is something I want to be able to do in the future.
The bearings look like they are just deep groove, not certain of the size yet. the spindle bore is MT5.
If I were to replace the bearings with a pair of nice AC ones, I could then hack a shaft in the gearbox and spindle shaft to use a toothed belt to drive the spindle.
The belt, cogs and tensioner would be trapped in the gearbox, which I was trying to avoid.. however I recon that a belt should last >1year so no issue.
The existing V belt drive can be replaced with more toothed belt and that could be used to provide ratio changes.. but I am hoping that I can get a beefy enough motor that there will be no need :-)
Now where is that growth hormone powder for the sherline?
Thanks.
JonLast edited by Jon S; 12-01-2012 at 02:02 PM. Reason: grama
CNC style lathe home brew Lathe for drilling and cutting.
By Bodge in forum Lathes, Lathe Rebuilding & ConversionsReplies: 9Last Post: 18-04-2012, 10:45 AM
