19-01-2012 #1
It is a very sad day indeed. :(
Up for sale is my trusty Roland PNC-3000 milling machine.
The reason for sale is after 6 years of great service I would like to upgrade to a larger machine.
It is a small desktop mill, great for everything from simple 2D profiling or PCB routing, through to complex 3D milling in light materials.
Back in the day I have been told this cost over £13,200(!) new and was lightly used to cut just MDF in a school's Design & Technology department before I bought it.
The machine is driven by a standard parallel printer port and comes complete with a large set of Roland software for use with this machine. For 3D parts, if your current CAD system can export .STL files then the Roland software can import and machine the model.
Ideally this machine is suited for light materials, such as plastics, machinable wax, tooling board, MDF and high density foam; although I have made a fair amount of aluminium parts on it, there isn't a great amount of grunt behind the spindle motor (100W), so you need to take light cuts.
The stock toolholder collet has been replaced with a more durable collet I have had custom machined. Two are included should one ever get damaged. The collet accepts 6mm plain shank tools.
Two printed and bound user and service manuals will be provided; including full schematics. I will include all the latest software updates and drivers on a CD.
You can find a video of the actual machine booting up and homing its axes here:
It would be very easy to convert this machine over to run under Mach3 (to run full G-code programs).
All that would be required would be the swapping of one of the I/O expander chips (socketed) on the main board and hooking up to a parallel port.
Another CAMM3 user, Andrew Loen, who designed the drop in replacement Mach3 board, details this in full in his YouTube videos:
http://www.youtube.com/watch?v=KTfs9lgCk1w
He also has a video of his CAMM3 being used as a laser cutter!
http://www.youtube.com/watch?v=9S5MEZANxyE
Machine Specification
- XY Table Size: 500 x 170mm - Axis Travel (X/Y/Z): 180 x 150 x 150mm - Precision: 0.01mm (0.005mm internal processing) - Max Feed Rate: 1.2m/min - Spindle Motor: 100W AC Motor - Weight: 55kg - Machine Size (W/H/D): 500 x 580 x 580mm (allow width on either side for table travel) - Interface: Parallel
Some photos of the CAMM3 are located below:
Please note: There is a slight issue with the machine in its current state. The X-Axis seems to occasionally and randomly miss steps when rapidly changing direction. I am unsure as to what has caused this issue. I have had a brief look at it, and have swapped over one of the stepper pulse generator chips with a known working one; and the issue remained. I can confirm the issue is not mechanical, as swapping the axis connection cords over, makes the issue occur on the Y-axis. Full schematics of the machine will be provided; I am sure it is such a simple issue to solve, perhaps a dry joint or something equally trivial I have overlooked. At the worst case, hook in a new stepper driver; and all is well. :)
Payment
Taking in account the minor stepper issue, I am asking £850 or best offer considered.
Delivery
Collection of machine preferred; will easily fit in the boot of a standard hatchback.
Will delivery locally (Nottingham) or further away at cost.
If you arrange your own courier, I will palletise the machine for collection.
Thanks for looking!
Any questions, don't hesitate to get in touch.
Best Regards,
Dan
19-01-2012 #2
Didn't realise they were only 100 watts spindle motor. How easy is it to swap the motor out for something with more grunt ?
Reason i ask is I bought one from a school a while ago but it's in storage at the moment.John S -
19-01-2012 #3
I shouldn't imagine it being too hard.
Just looks like a few allen bolts and a connector to me. As long as you can find something that would fit in the casting, all looks ok :)
The spindle speed sensor is done off the driven pulley, so that would still be displayed correctly. Spindle speed is set via the pot on the rear of the machine anyway.
I have not looked over the motor driver schematics, but I'm sure at the worst case, an alternative could be easily added.
I have just taken a photo of the mounting for you:
Hope that helps,
Regards,
Dan
20-01-2012 #4
I put in a half horse Amp-flow DC motor with a timing belt and an ER16 chuck. Hassle is the motor control is an zero cross over clipper feeding mains to the motor which has to go for DC. OTOH it does give the spindle revs as a voltage at the motor control board which is a small seperate item and easily replaced. It has a pot on it for speed control.
It runs a Z80 processor and you can pull the EPROM and reprogram it. It steps on the NMI which is a bit odd until you get the idea, you use INT for comms. I found the best feature was the 400 full step per rev motors, having half the usual pull in makes them rather wonderful.
25-01-2012 #5
Machine has been sold. Many thanks.
CONVERSION: Hacking a Roland CAMM3 PNC-3000
By Robin Hewitt in forum Conversion Build LogsReplies: 67Last Post: 22-09-2024, 08:55 AM -
Small desktop mill/router for cutting <=6mm aluminium
By matt-b2 in forum Marketplace DiscussionReplies: 2Last Post: 08-12-2013, 01:04 AM -
NEW MEMBER: Desktop CNC mill for narrow boat home office!
By robinc in forum New Member IntroductionsReplies: 0Last Post: 28-09-2011, 11:48 PM -
FOR SALE: For Sale! Roland PNC 3000 milling machine
By fidia in forum Items For SaleReplies: 17Last Post: 26-07-2011, 10:07 PM -
NEW MEMBER: Hi From Oxfordshire - with Roland CAMM3 machine
By rowifi in forum New Member IntroductionsReplies: 1Last Post: 15-02-2011, 05:04 AM
