15-01-2012 #1
I was hoping someone could give me some help with my Dore Westbury milling machine. I‘m not sure what the model number is though. (picture attached below)
I have absolutely no experience with milling machines so am finding things very confusing.
I need to be able to skim a fraction of material using a fly cutter.
As I mill across the material (winding away from me) the cut my side of the spindle is deeper than the cut the other side.
I have done a bit of research and I think the pitch of my machine is out?
I can see how you would adjust the yaw (which seems fine) but I cannot see how you could adjust the pitch?
Any help regarding this matter would be very much appreciated.
Many thanks
Richard
16-01-2012 #2
You need to put a dial indicator attached to a bar in the chuck to measure the relative height of the bed at a large radius. Measure the 4 points (x+,x-,y+,y-) to find how much it is out in each. To correct it you'll probably need to use shims. Search on google for 'tramming' a milling machine and you'll find lots of information about it.
WANTED: cnc milling machine
By bigred5765 in forum Items WantedReplies: 14Last Post: 25-04-2014, 11:08 PM -
FOR SALE: Seig KX1 CNC Milling Machine
By D2C in forum Items For SaleReplies: 2Last Post: 06-03-2014, 10:26 AM -
WANTED: X3 CNC milling machine
By Nemo1966 in forum Items WantedReplies: 1Last Post: 09-11-2013, 10:42 PM -
New CNC Controller for Milling Machine
By antsals in forum Electronic Project BuildingReplies: 26Last Post: 08-04-2012, 06:09 PM -
First CNC milling machine help
By newtoid1986 in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 05-09-2011, 10:06 PM
