16-01-2012 #1
https://tech.thk.com/en/products/pdf/en_a15_035.pdf#1
So there is more than one way of making a ballnut, again I learn something new :whistling:
I am struggling to see how the "Deflector Type" recirculates balls. From the diagram it looks like it happens in the middle of the nut, surely the return path should be at the ends of the nut? If that was the case then what is the difference between this and the return pipe version? :confused:
The preload options seem pretty simple, push the two nuts apart slightly or pull them together slightly or mess with the thread pitch. Surely messing with the thread pitch will lead to a shorter service life? When would each of the three pre-load methods be of benefit or inappropriate and why?
Thanks,
Jon
Identifying Steel types.
By cambesol in forum Metalwork DiscussionReplies: 11Last Post: 10-12-2013, 10:26 AM -
NEW MEMBER: Newbie - question on bit types
By Steven W in forum New Member IntroductionsReplies: 2Last Post: 16-05-2013, 12:06 PM -
Wire.. Oh why so many types....
By BedlamRik in forum General ElectronicsReplies: 5Last Post: 05-01-2013, 01:05 AM -
Pros and cons of climb milling in wood
By Richie in forum Wood Finishing Tips & TricksReplies: 15Last Post: 14-06-2012, 05:09 PM -
Hiwin linear blocks HGW 20 CC - what preload to spec?
By range3rrr in forum Rails, Guideways & BearingsReplies: 1Last Post: 24-08-2011, 11:44 PM
