    Hullo all.
    I am having a massive clear out due to an extension over the garage, MY space is smaller! So, I have a base / frame, very very robustly constructed welded steel. It was used as a base for my mill and since I constructed a wooden base to incorporate pc / keyboard etc (to save space) and is now surplus. My mill has sat on it for the last 15 years. There is some surface rust but only minor. It's powder coated baked enamel blue. Would idealy suit as a base for something like the Chester Champion 16V, 20V, Century or a small NC mill. It wouldn't take much to box it in to make draws / cupboard for tools.
    There is also a top to it, it was origionally a base for a manual digtiser, the top has a 10mm thick surface ground steel plate. The top has surface rust so isn't flat by my standards but would polish up easily. There are some mount holes it it already.
    Details:
    Height with feet 87.5cm (frame is 83.5)
    Width is 59cm
    Depth is 44cm
    Top holes are 36 x 51 cm centres bored m10 clear and all ground flat.
    It is constructed from 1 3/4 inch "L" steel 1/4 inch thick. The top plates are 3x3inches. It weighs about 25-30kg ish (guess), I haven't metricated yet but it's heavy.
    The separate top section is made from 1 1/2 inch by 3 inch, 1/4 thick box steel with a 10mm surface ground steel plate surface. It wieghs about the same.
    It is all welded, not spot or tacked (see photo).
    It has four adjustable felt bottomed feet.
    It could be easily used on it's side or on it's front to give a bigger base area and is ideal for a mill, drill or small lathe. It's obviously a buyer pick up but I would be happy to deliver it within a very resonable negotiable range for the cost of diesel @ 30mpg. (This probably won't be tonight, or tomorrow or the day after due to work load!!) But will likely be within a fortnight. I am based in Rothwell, Northamptonshire.
    I have included a pic of the mill and it's new wooden base to show what used to sit on it.
    It's engineered, very flat, very stiff, very strong and very stable. It has to be worth £50. £60 and you get the top section as well. Would very much prefer Paypal butwould be happy to consider any reasonable method of payment.
    Tom
ID:	5226Click image for larger version.
Name:	top bottom.JPG
ID:	5228Click image for larger version.
ID:	5229Click image for larger version.
Name:	new wood base.JPG
    Sherline lathe, Chester DB11V lathe, Myford/ Rodney mill, CNC mill Isel/ home made, Sealy Hack Saw, Meddings Pillar drill.
  1. BUILD LOG: A sufficiently strong machine
    By Jonathan in forum DIY Router Build Logs
    Last Post: 29-03-2014, 10:40 PM
  2. threading ground bar ends
    By dazza in forum Metalwork Discussion
    Last Post: 11-02-2014, 11:41 PM
  3. Strong 1212ds - any advice greatly appreciated!
    By MrWiz73 in forum General Discussion
    Last Post: 30-03-2011, 05:17 PM
  4. NEW MEMBER: Strong 1212DS - any good?
    By MrWiz73 in forum New Member Introductions
    Last Post: 29-03-2011, 11:13 AM
  5. RFQ: Precision Turned/Ground parts
    By Jimmybristol in forum Projects, Jobs & Requests
    Last Post: 08-01-2011, 04:12 PM
