Didn't realise they were only 100 watts spindle motor. How easy is it to swap the motor out for something with more grunt ?
Reason i ask is I bought one from a school a while ago but it's in storage at the moment.John S -
20-01-2012 #2
I put in a half horse Amp-flow DC motor with a timing belt and an ER16 chuck. Hassle is the motor control is an zero cross over clipper feeding mains to the motor which has to go for DC. OTOH it does give the spindle revs as a voltage at the motor control board which is a small seperate item and easily replaced. It has a pot on it for speed control.
It runs a Z80 processor and you can pull the EPROM and reprogram it. It steps on the NMI which is a bit odd until you get the idea, you use INT for comms. I found the best feature was the 400 full step per rev motors, having half the usual pull in makes them rather wonderful.
CONVERSION: Hacking a Roland CAMM3 PNC-3000
By Robin Hewitt in forum Conversion Build LogsReplies: 67Last Post: 22-09-2024, 08:55 AM -
Small desktop mill/router for cutting <=6mm aluminium
By matt-b2 in forum Marketplace DiscussionReplies: 2Last Post: 08-12-2013, 01:04 AM -
NEW MEMBER: Desktop CNC mill for narrow boat home office!
By robinc in forum New Member IntroductionsReplies: 0Last Post: 28-09-2011, 11:48 PM -
FOR SALE: For Sale! Roland PNC 3000 milling machine
By fidia in forum Items For SaleReplies: 17Last Post: 26-07-2011, 10:07 PM -
NEW MEMBER: Hi From Oxfordshire - with Roland CAMM3 machine
By rowifi in forum New Member IntroductionsReplies: 1Last Post: 15-02-2011, 05:04 AM
